Author Topic: key fob wont lock door  (Read 1587 times)
eddiesnow
« on: 19 October 2008, 19:54:55 »
I have fitted a new radio in a R Reg 2.0 Omega today, Now my central locking wont work. On the old radio had a red flashing light, has this got anything to do with it.
Please Help
Ade
Re: key fob wont lock door
« Reply #1 on: 19 October 2008, 20:08:39 »
not sure, maybe update your profile with your car(gls/cdx?) and location details and post what radio you had, maybe someone will know. Not sure on all the radio models on the omega tbh
eddiesnow
« Reply #2 on: 19 October 2008, 20:19:51 »
Sorted it now. I had a wire going to Permanent live for horn. Took that out, now it works. But now i have no Permanent live for radio memory.
Help Please
Ade
« Last Edit: 19 October 2008, 20:26:34 by eddiesnow »
unlucky alf
  • worksop, notts
« Reply #3 on: 19 October 2008, 20:30:19 »
there should be a perm live on the stereo plug, you might find that youve got to swap 2 wires over as i did [yellow & red] on the head unit, if youve got "bullet" connectors on your head unit wires plug yellow to red & red to yellow, that should sort it, what you are doing is swapping your acc live & memory live, had the same on all vauxhalls ive fittied after market head units to, :y
eddiesnow
« Reply #4 on: 19 October 2008, 20:36:10 »
Its a brand new stereo and it say the orange wire needs a Permanent Live.
Ade
unlucky alf
  • worksop, notts
« Reply #5 on: 19 October 2008, 20:56:09 »
hold on im being a berk!, i couldnt find a switched live on my miggy so had to join the switched live [acc live] & the perm live together if my memory serves me, i can check in the morning to make sure but pretty sure thats what i had to do :-/,  i take it your new head unit takes the standard 2 plugs, if so you will find it wont plug & play [which you have] & check to see if youve got a switched live first on the plug, if you have do what i said in my first post, if not follow above, it just means you can have the stereo on without the keys in the ignition.
eddiesnow
« Reply #6 on: 19 October 2008, 21:38:49 »
Swapped wires, put them together, keeped blowing fuses grrrrrrrrr
eddiesnow
« Reply #7 on: 19 October 2008, 21:43:02 »
This is what i have
Ground Wire Black
+12v Accessory/Switch (Red)
Power antenna/amplifer Turn On (Orange/White)
+12v Constant Power Supply (Orange)
Ade
« Reply #8 on: 19 October 2008, 21:46:45 »
On stereo plug on car, you find 12v, W contact (12v when ign on, and say on until key removed), and 0v.
unlucky alf
  • worksop, notts
« Reply #9 on: 20 October 2008, 16:23:25 »
TB does it depend on what year or type of miggy you have?, only i went through mine & couldnt find a switched live on the plug, out of desperation i went to the ignition switch, there wasnt one there either! [should there be??],all fuses were o,k thats why i connected my switched & perm live together, it was the only way it would work, my stereo [after market] i now have to switch off manually but as i take the face off its not a problem, the original head unit didnt work on the 1st position on the ign switch either, i suppose cos its mine its bound to be quirky :D
« Reply #10 on: 20 October 2008, 19:04:30 »
W contact is presented to radio on all Omegas.
W is 12v with ign on, but remains 12v until key removed. It is not 12v when key first inserted.
eddiesnow
« Reply #11 on: 24 October 2008, 12:28:11 »
Tried everything for this perm live, still no good. Not being technical minded, whet does the W stand for. If I went directly to the battery will this work
Ade
Page created in 0.026 seconds with 16 queries.
