Author Topic: auto box oil change  (Read 3416 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: auto box oil change
« Reply #15 on: 26 October 2008, 12:33:19 »
if you could mate, that would be brill. if it is that plug tho it's right behind the down pipe. just above the smaller box sump.
it's the one above the smaller sump pan on the drivers side...
tunnie, there's a small bolt in the drivers side i think it is on the larger sump pan on mine...
asin mine has a sort of drain plug besides the filler/level check plug hole
Thats been added by someone, never seen that before.
its a proper fitting matey, got an allen key plug on it
bout 22mm diametre flat with allen key hole in middle of it
V8!!!!
kris9128
« Reply #16 on: 26 October 2008, 12:53:41 »
any body want some beer tokens.
ngrainqey
  • rotherham
« Reply #17 on: 26 October 2008, 12:56:11 »
lol no but thanks anyway, have you seen that pic on page1 matey?
V8!!!!
« Reply #18 on: 26 October 2008, 14:06:46 »
Like i say, that has been fitted by someone, Vauxhall never put that on the Omega gearbox. Its been retro fitted by a previous owner  :y
kris9128
« Reply #19 on: 26 October 2008, 16:10:50 »
just to clear a few things up. having just finished the atf change. the bolt on the sump is not a drain plug. it's a level check. the new oil does go through said hole. i can also confirm that removing the sumps is a bloody messy job. not difficult to do, just bloody messy. all done now tho  :y :y :y
