Author Topic: idling  (Read 1680 times)
Omegadoha, Desert Member
  • Doha, Qatar
idling
« on: 25 October 2008, 18:28:06 »
When starting up the car from cold, I notice that the revs go up and down from 500rpm to about 800rpm and then settles at 500. Is it normal for the revs to go up and down?
Is there anything that can be cleaned out?
geoff
  • thornaby,stockton on tees
Re: idling
« Reply #1 on: 25 October 2008, 18:39:06 »
clean idle control valve and breathers out should be o.k :y :y :y
  • Doha, Qatar
Re: idling
« Reply #2 on: 25 October 2008, 18:46:28 »
Thanks Geoff.
Is the IACV cleaning detailed in the breather cleaning guide for the V6?
Many thanks.
geoff
Re: idling
« Reply #3 on: 25 October 2008, 18:48:19 »
i thinks so m8y :y :y :y
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: idling
« Reply #4 on: 25 October 2008, 18:49:54 »
there should be a "cleaning the 2.0 icv" in how2 section
V8!!!!
  • Doha, Qatar
Re: idling
« Reply #5 on: 25 October 2008, 18:54:24 »
thanks again!  :y
Re: idling
« Reply #6 on: 26 October 2008, 08:16:41 »
3.2  2.6 and i think the 2.2 are all drive by wire. So no throttle cable and no icv  on the 3.2. and 2.6( not sure about the 2.2 so ill leave that out its not relevant anyway) All the throttle work including tick over is handled by the throttle body afaik. My 3.2 can be a tiny bit erratic at times and have put it down to the electronics sorting itself out from cold when i put the lights on heated windows and heaters/ac or what ever. If your car has always done this i would not worry. If its a new development then whats the cause? Dont know for certain, but you could try cleaneing the throttle body, as you would an icv, but if mine is anything to in by it wont be that dirty.
Air leak in the induction system, but that would happen all the time not just from cold. The ac can affect the tick over as it clicks in and out, but i am bloody sure youd know if the ac was busted liveing out there. Has the car always done this?
Ps do you remember a post a while back about the 3.2 cranking but not starting? We put it down to hot weather, iirc, thing is mine did it again yesterday, it was raining and cold. Only thing of note was the fuel light was on. Bloody Gremlins live in there i tell you...
I also wonder about crank sensor issues with these things, but no relevant codes in my car. You could try the pedal trick as listed under paperclip test, its bottom of page 1 in maintenance section, and see if you any fault codes stored. Constant flashing means no codes.
  • Doha, Qatar
Re: idling
« Reply #7 on: 26 October 2008, 16:27:08 »
Thanks for that. Perhaps I'll try cleaning the breathers. It holds for two secs at 500rpm and then goes up for 2 secs at 800 rpm. And when slightly warm just settles at 500rpm , like it never happened.
Re: idling
« Reply #8 on: 26 October 2008, 17:46:50 »
mine is exactly the same. Just warning up.
Sorry thats a bit of a short reply. Was going out in the car and paid attention to the tick over for once. It starts and goes up to 800rpm and when warm drops to 5 maybe 600rpm. Nothing to worry about.
Sorry i did not post that at the start. Never paid much attention to it tbh.
« Last Edit: 26 October 2008, 22:12:27 by chrisgixer »
