Author Topic: Front disc replacement 2.5 facelift  (Read 1437 times)
ianu
  • Oxfordshire
    • XC90/Maserati QPV/CooperS
« on: 26 October 2008, 20:27:34 »
Hello all - can I ask for some advice on when to change the front discs on a 2.5 facelift (Cd estate).
Is there a minimum thicknes spec I can measure - or is there a rule of thumb regarding the 'lip' around the edge of the disc ? I've also heard the term 'matched' replacement pads ?
I'm happy to go the genuine part route - do you know which diameter discs they are too as there seem to be 2 sizes on Autovaux site ?
Cheers
Ian.
Re: Front disc replacement 2.5 facelift
« Reply #1 on: 26 October 2008, 20:31:19 »
all omegas take the same brake disc size, only very early 8v 2.0's had smaller discs.
Get geniune, brakes is one area not to penny pinch. Set of discs and pads from a dealer is around £80.
« Last Edit: 26 October 2008, 20:32:40 by tunnie »
« Reply #2 on: 26 October 2008, 20:31:45 »
If they look worn I just replace them, they're cheap enough and not a bad job to do... :y
« Reply #3 on: 26 October 2008, 20:33:55 »
....... Set of discs and pads from a dealer is around £80.
If you have access to a 'Trade Club Card'  ;)
Min thickness according to Mr Haynes is 26.5 mm (new28 mm)
« Reply #4 on: 26 October 2008, 20:37:41 »
Depends if you have access to a bottomless pit of cash. eg 2 MOTs ago the tester noted the the discs on SWMBO's Astra were both 'worn to min' It's since passed 2 MOTs with no further comment on the same discs.
The only thing to note about an unworn lip on an otherwise OK front discs is that it will trigger the low brake pads message earlier than it needs.
« Reply #5 on: 26 October 2008, 20:44:45 »
All Omegas take 296mm discs, except pre 1997 2.0l ones (286mm)
Markjay
  • London
« Reply #6 on: 26 October 2008, 20:49:55 »
Get them done, just in case...
Alas, no more Omegas....
ianu
  • Oxfordshire
« Reply #7 on: 26 October 2008, 21:14:42 »
..sounds good to me - I've checked out the 'how to' pages and looks pretty straightforward as you say.
Cheers all - I'll put it on  my list of things to do next month.
Thanks
Ian. :y
