Author Topic: Door check straps  (Read 1598 times)
gstylebaby
  • stockport
Door check straps
« on: 26 October 2008, 18:11:43 »
My drivers side rear door never stays open and makes a nasty sound.....Am i right in guessing its the check strap cause i have tryed to clean it grease it and still it hates me just want to make sure before i get one.  In fact i mite change all of them over to newer ones.
  • Online Online
Re: Door check straps
« Reply #1 on: 26 October 2008, 18:13:48 »
It's usually the check starp having pulled throughthe door skin, so you need to sandwich what's left of your door skin with 2 of the repair plates.
gstylebaby
  • stockport
« Reply #2 on: 26 October 2008, 18:35:23 »
Repair plates mate???????? You got me there pal :-/ :-/
HolyCount
« Reply #3 on: 26 October 2008, 18:45:44 »
Vx do a repair kit for this -- I used a couple of penny washers either side of the split -- works a treat.
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #4 on: 26 October 2008, 18:52:07 »
See link m8 you can buy these but I made some myself if you got a piece of thin steel :y
http://www.omegaowners.com/forum/YaBB.pl?num=1152902108/0
valliant72
  • London
« Reply #5 on: 27 October 2008, 02:07:07 »
Repaired mine using 4 large washers from BQ, bit fiddley but sorted the problem  :y
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #6 on: 27 October 2008, 05:53:46 »
His problem is with the back door if I read correct, and the system is different than in the front... No idea of the repair though...  :-X
HolyCount
« Reply #7 on: 27 October 2008, 09:55:07 »
That will teach me to read properly  :-[
Page created in 0.028 seconds with 16 queries.
