Author Topic: Odd Climate Control problem  (Read 2165 times)
« on: 28 October 2008, 20:32:44 »
As said .. CC is misbehaving more and more ... mostly it works fine when the car is started from overnight stop, but when started warm the CC plays up, mostly running cold, and even with "demist" selected the airflow is mostly out of the centre vents instead of the screen vents. It also feels like "re-circ" is stuck on as things steam up pretty fast.
Press "auto+off" for anything up to a minute and occasionally the fan slows and the system runs to max hot then backs off to behave more reasonably, but mostly the reset just does not occur at all. Switching off and back on makes no difference.
If, whilst the CC is playing up, the car is switched right off and key removed for at least 2 minutes... then on restart it generaly (8 out of 10) works as it is supposed to !!
When it is playing up it is actually getting a tad dangerous at the moment as the screen fogs up very quickly, when it works properly it does so for hours and is a dream....
CC firmware was updated by TB at the WIM openday way back .. and as this problem had occured a couple of times, so classed as "infrequent" ... Mark DTM checked it, but did not "re-install" at Newent, the software was reporting no faults and the correct firmware number.
Scuttle drain is spotless, no damp in the carpets and the coolant system does not use ANY fluid at all.
Anyone any ideas ??  I'm stumped.. :(
« Last Edit: 28 October 2008, 20:33:18 by entwood »
VX1
  • Reading, Berkshire
Re: Odd Climate Control problem
« Reply #1 on: 28 October 2008, 20:39:39 »
Entwood........Firstly did you go to the caravan show last weekend?
Secondly have you tried to reset the CC?
Paul  :y
Vx Trade club card holder
Halfords trade card holder
« Reply #2 on: 28 October 2008, 20:42:36 »
Paul  :y
Firstly Yes ... and spent rather a lot ...  :)
Secondly ... read para 2 ...   :)
 :D :D :D :D
VX1
« Reply #3 on: 28 October 2008, 20:45:14 »
Paul  :y
 :D :D :D :D
Oooppss should be wearing my glasses doh!!
The family and I went, had a good look round spent about £20, good day out loved the vans but wanted to take most of them home  :(.
Paul  :y
« Reply #4 on: 28 October 2008, 20:47:26 »
i tried the reset the other day. I could only get it to work with the key in position 2, engine off...???
« Reply #5 on: 28 October 2008, 20:50:20 »
Interesting .. I'll certainly try that tomorrow ...  :y :y :y
Thanks .. :)
« Reply #6 on: 28 October 2008, 20:51:36 »
Paul  :y
 :D :D :D :D
Paul  :y
mmmm....  mutiply that by about 300 .....    :(
VX1
« Reply #7 on: 28 October 2008, 20:53:52 »
Paul  :y
 :D :D :D :D
Paul  :y
So you bought one then ouch!! Which one did you go for in the end? Sorry for coming away from the original post entwood. Was looking out for you but didn't see you at all  :(
Paul  :y
« Last Edit: 28 October 2008, 20:54:37 by vauxhallomega1 »
« Reply #8 on: 28 October 2008, 21:19:06 »
Abbey 416 Spectrum ....
http://www.swiftgroup.co.uk/caravans/abbey/spectrum
I'm sure the experts will pick past our "pikey wagon" discussions and enlighten me on the CC problem in their own time .... no doubt petrol and matches will crop up at some point !!
 ;D ;D ;D ;D ;D ;D
« Reply #9 on: 28 October 2008, 21:22:23 »
 ;D ;D ;D ;D ;D ;D
So you bought one with shite LED lights then!  ;D ;D
« Reply #10 on: 28 October 2008, 21:25:06 »
 ;D ;D ;D ;D ;D ;D
So you bought one with sh*te LED lights then!  ;D ;D
yup ... now ... about this CC problem ...   ;D ;D ;D ;D
« Reply #11 on: 28 October 2008, 21:25:56 »
Lol, you will be ditching them fast....
Anyway, climate fault.
I assume external temp is reporting ok on CID?
« Reply #12 on: 28 October 2008, 21:27:00 »
yup .. was showing 3 degrees on the way home... and as it was sleeting at the time I believe it to be reasonably accurate !!
« Reply #13 on: 28 October 2008, 21:40:52 »
 ;D ;D ;D ;D ;D ;D
Real nice caravan mate. :y
« Reply #14 on: 28 October 2008, 23:43:01 »
 ;D ;D ;D ;D ;D ;D
:'( ;D :'( ;D :'( ;D :'( ;D :'( ;D :'( ;D :'( ;D :'( ;D :'( ;D :'( ;D :'( ;D stop stop please stop. I am going to wet myself. :'( ;D :'( ;D :'( ;D :'( ;D :'( ;D :'( ;D :'( ;D :'( ;D :'( ;D :'( ;D
 mercedes sprinter included?
