Author Topic: Oil Leaks  (Read 858 times)
Spirited1
Oil Leaks
« on: 29 October 2008, 15:26:57 »
Hi
i'm a newbie, with a problem. Not being mechanically minded, I am having problems with my S Reg Omega 2.5 petrol. Oil leak to be exact, is there a common fault with this vehicle, its got approx 100k with FSH.
However i think my mechanic is taking the P**s out of the fact i am not a mechanic and has been fixing and replacing all sorts, rocker box gasket, dip stick, sump gasket, and some other seals!
I know change my mechanic (i am looking for one on recommendation), in the meantime i need some advice on the leak, if possible.
The current mechanic is saying there is a flap on the dip stick that is not working, so the pressure is building when the engine is running and blowing oil out - is this feesible.
Thanks for your help  :)
Re: Oil Leaks
« Reply #1 on: 29 October 2008, 15:28:08 »
Hi
So ahs your mechanic done the obvious...........and cleaned out the breather setup?
Re: Oil Leaks
« Reply #2 on: 29 October 2008, 15:32:24 »
(i am looking for one on recommendation), in the meantime  .....
 .... but we don't know where you live!  ;)  ;)  ;)
eddie
  • Cardiff
Re: Oil Leaks
« Reply #3 on: 29 October 2008, 15:43:12 »
I think he needs a flap on the mouth to stop the rubbish coming out..... :-?
If your anywhere near Cardiff then PM me.
eddie
