Author Topic: So then, these codes...  (Read 1931 times)
GmasterT
  • Cambridge
  • does that drifting thing...
« on: 29 October 2008, 14:10:21 »
Did the 'pedal trick' and got a couple I dont understand, can anyone shed any light?
I think I got the U2100 CANBUS malf, whats that?!  :-?
Also got 0805?!
and whats a vehicle speed malfunction (0500)
thanks  :y
Re: So then, these codes...
« Reply #1 on: 29 October 2008, 15:48:46 »
If you are geting a result with the "pedal trick" you must be OBDII .. or so I believe .. in which case ...
http://www.obd-codes.com/trouble_codes
Will give all the answers .. :)
« Reply #2 on: 29 October 2008, 16:56:03 »
Also got 0805?!
thanks  :y
I have an 0500 from the rolling road day. The dyno confused the abs as the rear wheels where flat out and the fronts where at a stand still. Which then confused me because i thought the pedal trick only read the engine ecu. But the speed sensor is part of the engine ecu s parameters. So thats that. So sounds like you ve been playing  to me? Fair play.
GmasterT
  • Cambridge
« Reply #3 on: 29 October 2008, 17:19:15 »
Also got 0805?!
thanks  :y
Ah, that would be my afternoon of drifting at the pod... So will that throw up the engine man light every time as I intend to use her fairly often at drifty days...
And cheers Entwood, will have a look later when I get some more time, just getting used to having a 'new' car with faults I A: dont understand and B: cannot solve with a spanner and hammer even if I did!
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #4 on: 29 October 2008, 17:25:58 »
while we're on about fault codes... whats the hall effect sender fault mean? it's code 94 in old omega terms lol (motronic and simtec 2 digit codes)
V8!!!!
GmasterT
  • Cambridge
« Reply #5 on: 29 October 2008, 17:43:59 »
I always thought hall effect sensors where to do with modern type 'points' or something, but gather you would have direct ignition?
iainb
  • West Midlands
« Reply #6 on: 29 October 2008, 17:55:39 »
ngrainqey
  • rotherham
« Reply #7 on: 29 October 2008, 18:06:31 »
Hall effect
http://en.wikipedia.org/wiki/Hall_effect
riiight, whats the hall effect sender for then on the omega and whats up if it's got a fault? knackered?
V8!!!!
iainb
  • West Midlands
« Reply #8 on: 29 October 2008, 18:13:41 »
Is it a tractor ?
« Reply #9 on: 29 October 2008, 18:28:09 »
Also got 0805?!
thanks  :y
You may get the abs light on, may not, but it will go out when things return to normal. But it will store a code as you have seen. No need to worry about it now though. Thing is with codes is, they are not time relevent, so its wise to note all codes and then erase(with a code reader) and see if it returns. Then you have an idea of the time scale involved and then weather to bother with fixing it or not. Hth
ngrainqey
  • rotherham
« Reply #10 on: 29 October 2008, 18:30:28 »
Is it a tractor ?
na it's a v6 matey, crank sensor 19 was there too so gna swap that.would crank sensor stop it starting?
V8!!!!
iainb
  • West Midlands
« Reply #11 on: 29 October 2008, 18:32:13 »
Yep sure would. :)
rickyboy
  • Glasgow
« Reply #12 on: 29 October 2008, 18:41:49 »
Cam or crank sensor.  If it's a v6 change the crank sensor, if it's a 4 pot change the cam sensor.
« Reply #13 on: 29 October 2008, 19:18:27 »
hall sensor, 94, will be cam sensor
ngrainqey
  • rotherham
« Reply #14 on: 29 October 2008, 20:08:56 »
doh!
theres no chance of it throwing up 94 randomly with the cranksensor gone?
cam sensor went on my 2.0 before i ripped the engine out of it grrr! stupid cam sensors
V8!!!!
