Author Topic: How urgent cam cover seals  (Read 1170 times)
fatboyfat
  • leeds
« on: 29 October 2008, 15:21:19 »
Hi all,smoke on right side of engine,as you look at it from front,cam cover seals how likely and how urgent to get fixed.I was hoping to get a list of stuff to do all together but dont know how urgent this is.Also checked oil level and there is much more in than level on dipstick says should be,will this have knackered the seals.Thanks
God only created a few perfect men
The rest he gave them hair
hotel21
  • The Kingdom of Fife
Re: How urgent cam cover seals
« Reply #1 on: 29 October 2008, 17:39:02 »
Suggest that you give the car an oil and filter change, refilling to the correct mark on the stick.
Leak is probably the camcover gaskets.  Get kitchen roll or a syringe and plastic tube and suck out the excess oil from the plug wells.  Depending on how much is physically running down the side of the engine, you could leave it for a wee while, until the smell of burnt oil gets too overpowering.
Check out the howtoo guide in the maintenance section.  Dont forget to clear the breathers at the same time.....   :y
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #2 on: 29 October 2008, 18:18:21 »
Depends on the leak...
had mine set on fire from a minor leak once... though I had just drove the car in full on anger mode...
« Reply #3 on: 29 October 2008, 18:30:00 »
If they're leaking into the plug wells, it could turn into a bigger and much more expensive job. Plugs + Leads + DIS pack. Best to bite the bullet IMHO.
« Reply #4 on: 29 October 2008, 19:21:55 »
in my experience do asap. The longer you leave it the more likely you will damage plugs leads and then dis pac as said, but i also had failed alternator, covered in oil, plus what ever damage the oil will do to rubber hoses, have seen a post on here re blown coolant pipe under the oil filler, it had been eaten by the oil. Rubber and oil dont mix., unless oil resistant like seals. Coolant pipes aint.
fatboyfat
  • leeds
« Reply #5 on: 29 October 2008, 23:06:53 »
Cheers guys.Am going to join ABS but money as always tight,can i be cheeky and ask if anyone can help with tradecard for cam seals.Thanks again.That is unless i save £20 or more on cost of seals with ABScard.Thanks again. :y
