Author Topic: heater fan  (Read 3517 times)
painter
heater fan
« on: 25 October 2008, 10:02:14 »
Hi to everyone
newbie from south wales here just found your excellent site whilst trwling the web for help with my omega. I have a 2003 2.2 cd with 51k on it all seems fine on the car except for the heater fan the display says it is blowing but it definatly isn,t and all fuses seem fine. maybe a relay?? or the dreaded fan motor?? any guidance appreciated.
I wouldn,t normaly join a forum with a question but i do hope i can contribute something usefull in the future. thanx dave
painter
Re: heater fan
« Reply #1 on: 25 October 2008, 17:08:44 »
Does the lack of responce mean no omega heater motor ever stopped working ??? :o :o :o
Re: heater fan
« Reply #2 on: 25 October 2008, 17:11:24 »
I would check fuse F33 first (top left of teh fuse box).
Also, any signs of water in the passenger footwell?
Re: heater fan
« Reply #3 on: 25 October 2008, 17:20:01 »
If its the fan motor you will need to remove glove box, cable tray (cut all the black tape!!) to remove - 3 torx screws IIRC.  Awkward fiddly job :(
Re: heater fan
« Reply #4 on: 25 October 2008, 17:50:04 »
Hello and a warm welcome to you Painter! :y
Although I cannot help you on this one, as you have already seen there are plenty of Omega experts on here who will be able to. ;)
geoff
  • thornaby,stockton on tees
Re: heater fan
« Reply #5 on: 25 October 2008, 18:17:49 »
could be fan motor blower,as said glove box has to be removed,changed one on mine about a year ago when brother in law owned it,quiet fiddley to change and a lot of bad language
Mike Collins
  • North of Bristol
Re: heater fan
« Reply #6 on: 25 October 2008, 19:58:05 »
It's likely to be the fan control module, fitted in the fan casing and needs the the glovebox removed to access.  Changing the fan is not so easy so it's worth trying an external supply to prove the motor is ok.
ballcock50
  • South Wales
Re: heater fan
« Reply #7 on: 25 October 2008, 19:59:32 »
Hi! Painter, has your car got air con or just heating, could possible be the fan speed resistor which is also near the fan. I had a poor connection on climate control switches which stop mine working.
painter
Re: heater fan
« Reply #8 on: 26 October 2008, 14:04:49 »
Well thanks to everyone for your time interest and comments, I have now checked the fuses and they seem fine inc the large f33 fuse, the digital display on the dash lights up ok including the fan switch little bars showing the speed of the fan, so i assume the power is reaching the switches ok. there is no evidence of water or damp on the footwells so I guess i should now be removing the glovebox to access the motor??? does anyone know the location of any relays beore i take such drastic measures??
Matchless
  • Nottingham
    • A white van
Re: heater fan
« Reply #9 on: 26 October 2008, 14:40:56 »
Digital display so you have an electronic motor speed control module which sits in the fan caseing and is cooled by the airflow.
The module can be water damaged, what happens is the drain hole for the air intake plennum gets blocked with leaves and rain water builds up until it gets to the level of the fan intake then it trickles into the control module.
If you remove the glove box you will see the module, it is about 2" / 50mm square and clips into the fan housing. Remove it and prise off a small plastic cover by the terminals. If there is furry corrosion inside then thats your problem.
To confirm it, follow the wires into the fan motor, find the two thick ones and apply 12V to it, you should get full speed fan if the motor is OK.
Modules cannot be repaired, you will have to find one from a breakers.
painter
Re: heater fan
« Reply #10 on: 26 October 2008, 14:51:56 »
very informative thank you tomorrow I will have a go,  i expect it is well known on here but in south wales we have an excellent vauxhall breaker on the outskirts of caerleon and they only break Vauxhall
thanks to everyone
Re: heater fan
« Reply #11 on: 26 October 2008, 18:17:40 »
painter
Re: heater fan
« Reply #12 on: 26 October 2008, 18:29:29 »
thanks for the info
sulli1
  • Gary, Indiana US
Re: heater fan
« Reply #13 on: 27 October 2008, 15:56:53 »
Thanks to all, and thanks to Painter for the question, as I also have the same problem. Cleaning the leaves and twigs definitely allows the water to drain.
painter
Re: heater fan
« Reply #14 on: 27 October 2008, 16:12:11 »
Hi People so far so good with the strip down (the car not me !!!)  I can now see the heater motor having removed the glove box and untaped the wiring from the plastic tray but think I need to remove the airbag to get at it clearly, any advice on removal or dis arming airbag will be gratefully recieved before I go back foir round 2 tomorrow, many thanks and regards   Dave
