Author Topic: emmisions warning light on 2.6omega  (Read 768 times)
caran10
  • coventry
« on: 31 October 2008, 09:43:48 »
i have just bought a 2001 2.6 omega and the emisions light is permanently on  i have had a tech 2 done on it and it comes up ( fuel trim malfunction banks 1 & 2. codes P0170 & P0173 . I have been told it could be theAir Mass Flow gauge . has anyone had the same problem
Re: emmisions warning light on 2.6omega
« Reply #1 on: 31 October 2008, 09:47:11 »
Firstly, welcome to the forum!  :y :y :y
I'm afraid I can't remember the answer to this but if you search for the fault codes it will be there! Someone has recently had the same problem.
I expect there'll be an answer soon anyway.
Can I suggest you update your profile with car and location becaus you will get asked it a thousand times otherwise ;) ;)
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #2 on: 31 October 2008, 09:49:40 »
I had the same codes and the local Opel-shop said it might be the MAF, I changed it without any success. However, the light has now gone away, so it might be relatetd to the pre-cat-issue which is a know problem with 2,6/3,2 engines.
One thing might be an air leak, I found once the small 90 degree rubber hose that connects to the front of multiram loose and that may also have been related to the codes.
Page created in 0.026 seconds with 16 queries.
