Author Topic: timing belt tensioner...what you think?  (Read 1538 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« on: 31 October 2008, 21:41:36 »
hiya, just bought my new toy and took the timing belt cover off.
found the rubber bit from between the inner and outer plastic timing belt covers dragged into the timing belt, the tensioners gone but what d'ya think... set timing up again and see how it runs or stick another engine in that i'v got?
*edit
can somebody tell me which tensioner/pulley assembly i need for a '95
v6, watched the timing belt dvd (excellent dvd ;) ) but cant remember for the life of me which one i need to get
thanks
« Last Edit: 31 October 2008, 22:05:38 by grainqey »
V8!!!!
Matchless
  • Nottingham
    • A white van
Re: timing belt tensioner...what you think?
« Reply #1 on: 31 October 2008, 22:05:18 »
Nothing to lose, so fit a tensioner (s/h would do) and check for missing teeth or damage on the belt.
If valves are badly bent it will spin over too freely, if it runs and sounds OK then do a vacuum check...should be 19" when warm, much less could mean valves are slightly bent.
ngrainqey
  • rotherham
« Reply #2 on: 31 October 2008, 22:07:10 »
well it'll want a new belt as there's a tear in the belt (wouldnt have lasted much longer i dont think is it was torn half way through the belt) but the teeth looked fine actually, but outside was glazed and cracked
V8!!!!
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #3 on: 01 November 2008, 01:24:15 »
*edit
thanks
Check what your engine number is on your V5 then get one according to that number (if its original engine of course) :y
ngrainqey
  • rotherham
« Reply #4 on: 01 November 2008, 11:13:15 »
i wont have the V5 for like 3 weeks as it'll have been sent off.
i imagine off the top of my head that it's the EB assembly that i need as it's a 95 so should be the earlier set of engine number (dont worry i'll double check before i get one) unless some monkey has put the newer/later one on instead- tbh it wouldnt suprise me if it was only the belt that'd been changed.
i changed my 4pot timing belt and the idlers looked pretty good it has to be said!
V8!!!!
Page created in 0.026 seconds with 16 queries.
