Author Topic: Replacing Cam Cover Gaskets - How Difficult Is It?  (Read 10253 times)
Kate
  • Cornwall
    • Drives people mad
« on: 26 October 2008, 10:04:43 »
How hard a job is it to replace cam cover gaskets on a V6?  Could a beginner do if she followed the instructions on the oof?
I was thinking of trying it myself due to severe money problems.
What do you all think?
Ian_D
  • York
Re: Replacing Cam Cover Gaskets - How Difficult Is It?
« Reply #1 on: 26 October 2008, 10:09:49 »
It depends...   :-/
Its not an easy job, but its not hard either!
It more fiddly than anything... and if you have a lot of patience, then you 'SHOULD' be ok... ::)
Have you ever worked on engines before though? as its not really the ideal 1st job to tackle really!  ;D
[size=12]
razzo
  • Crapital
    • 97 3.0 Elite
« Reply #2 on: 26 October 2008, 10:23:13 »
give it a go, just be methodical about it & take your time  :y
Martin_1962
« Reply #3 on: 26 October 2008, 10:32:20 »
Start on the drivers side and 8Nm is not very hard and can be guessed at (hold rachet in middle and just nip them up)
GEDFORDM6
  • Cleveland
« Reply #4 on: 26 October 2008, 10:43:41 »
Hi,you should be able to do it just mark everything up and take photos as well.Dont forget to clean the breather pipes while its stripped down,one of mine was completely blocked and probably the cause of gaskets blowing.Good luck.. :)
Kate
  • Cornwall
    • Drives people mad
« Reply #5 on: 26 October 2008, 14:42:59 »
Well thanks for the advice! :y
I thought I would check the tightness of the cam cover bolts today and one snapped.  I didn't even tighen it very hard.  Will I be able to remove it with pliers with the cover off do you think?
« Reply #6 on: 26 October 2008, 14:46:00 »
The top of the bolt sheared off?
Have to take the cover off, try some mole grips on it.
Kate
  • Cornwall
    • Drives people mad
« Reply #7 on: 26 October 2008, 14:49:55 »
Thanks.  If I ever get the courage to start I'll try it. :y
Kate
  • Cornwall
    • Drives people mad
« Reply #8 on: 26 October 2008, 14:51:55 »
Can you buy the bolts btw?
« Reply #9 on: 26 October 2008, 15:00:51 »
As stated already it is not too difficult as mechanical jobs go, but it is certainly awkward and fiddly. ::) ::)
Follow the Guide, but note that it is easier to dismantle the wipers and fold back the scuttle panel to obtain better access, and when it comes to removing/replacing the passenger side engine bank cam cover it is best to pull back and tape/string up all the pipes and wires you can.  Then various things, including the cam fixings themselves, will not so easily manage to pull off the cam cover gasket that you have so carefully put into place!! >:( >:(
I also managed to avoid completely disconnecting the throttle controls from the plenium, so I could simply 'flip it over' and move it out of the way with those cables still connected. 8-)
Also you have got to make double/tripple sure as you replace the cover (for both sides, but especially the passenger side) the half moon piece of gaskets squarely lines up with the corresponding cut out on the head.  The DIS / engine lifting unit right in the way there can make that very difficult to check! ::) ::)
In addition do not do what I, and apparently others, have done and trapped the Knock Sensor wire (adjacent to the Idle Control Valve) in between the front of the cam cover and the cam belt drive housing/top of engine!! >:( >:(
Hope this helps a bit Kate, but if you require further advice just ask as usual. :y :y
Believe me, once you get into the routine of this job it is straightforward enough. :D :D ;)
« Last Edit: 26 October 2008, 15:02:14 by Lizzie_Zoom »
Kate
  • Cornwall
    • Drives people mad
Kate
  • Cornwall
    • Drives people mad
« Reply #11 on: 26 October 2008, 15:48:31 »
I got a quote from the Vauxhall dealer in Sunderland.
They said I would have to pay for new covers as well as the gaskets as they don't sell them seperately.
The price quoted was £373! :o
More than the mig cost! :o
« Reply #12 on: 26 October 2008, 16:05:51 »
Thanks for that Lizzie! :y
Does anyone know if this set is any good:
http://cgi.ebay.co.uk/Vauxhall-OMEGA-SAAB-V6-CAM-ROCKER-COVER-GASKET-SET-NEW_W0QQitemZ370075063077QQcmdZViewItem?hash=item370075063077&_trkparms=72%3A1301%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Personnally Kate I would always just stick to genuine Vx gastets from your local dealer at about £51.42 +VAT for the pair with TC. ;)   Vx Part No 090511451 for 2.5V6 :y
These do not appear to be genuine with other manufactures mentioned, although I could be wrong! ::) ::)
« Last Edit: 26 October 2008, 16:09:28 by Lizzie_Zoom »
« Reply #13 on: 26 October 2008, 16:07:30 »
Absolute bollxxks!!
Vx Part number 090511451 for 2.5 V6 :y  You need two at £25.71 +VAT with a TC. :y
« Last Edit: 26 October 2008, 16:10:17 by Lizzie_Zoom »
« Reply #14 on: 26 October 2008, 17:18:29 »
Absolute bollxxks!! .......
You don't agree then?!?!  ;) ;)  :y :y
