Author Topic: Climate Control  (Read 1421 times)
V8 RUMBLE
  • NORTHANTS
Climate Control
« on: 30 October 2008, 17:54:33 »
Hi
I own a P reg 2.5 td and at the moment do not have very much climate at all. My car will only blow cold air on the screen but nowhere else. Some heat (not very much) drifts out of the driver's side vent in line with the steering wheel. I have tried to re set it by holding the buttons advised in the Haynes manual but still nothing. Where would be the best place to start to look. Thanks in advance for any help.
Tim :)
Re: Climate Control
« Reply #1 on: 30 October 2008, 18:34:30 »
Hello fellow tractor owner ;D
When you switch off ign, do you get -- in the climate display for about a second?
V8 RUMBLE
  • NORTHANTS
Re: Climate Control
« Reply #2 on: 31 October 2008, 16:52:33 »
Hi
Sorry for the delay the local Wetherspoons had curry and a pint for a fiver last night. Yes I do get that when I turn the ignition off. ;)
Re: Climate Control
« Reply #3 on: 31 October 2008, 17:12:27 »
Hi
Fault stored in climate system then.  Ideally, get the climate ecu read, and see what it thinks is wrong, then you can tackle the problem (which invaraibly means taking part of dash out)
V8 RUMBLE
  • NORTHANTS
Re: Climate Control
« Reply #4 on: 31 October 2008, 17:16:05 »
Thanks for that. Can my local garage read the ecu or is this a dealer only type thing?
Tim
Re: Climate Control
« Reply #5 on: 01 November 2008, 11:25:17 »
Tim
dealer, or http://theboy.omegaowners.com
V8 RUMBLE
  • NORTHANTS
Re: Climate Control
« Reply #6 on: 01 November 2008, 20:55:59 »
Thanks for the info, it wil have to be dealer then as I am a Newbie.
Tim
 :y :) ;)
Re: Climate Control
« Reply #7 on: 01 November 2008, 22:45:00 »
Tim
 :y :) ;)
PM sent
V8 RUMBLE
  • NORTHANTS
Re: Climate Control
« Reply #8 on: 02 November 2008, 13:29:27 »
Could you re send I think my spam must have took it out
Re: Climate Control
« Reply #9 on: 02 November 2008, 13:41:36 »
no spam filtering on PMs ;)
V8 RUMBLE
  • NORTHANTS
Re: Climate Control
« Reply #10 on: 02 November 2008, 15:22:12 »
Oops blond moment ::) ;D
