Author Topic: BONNET CATCH,,,,COOLANT  (Read 1052 times)
andycab
  • llanelli
« on: 02 November 2008, 14:58:53 »
I CANT SEEM TO OPEN BONNET USING CATCH ,ANY WAY TO OPEN FROM OUTSIDE......ALSO WHATS CAPACITY OF COOLANT SYSTEM
                                    THANKS
Re: BONNET CATCH,,,,COOLANT
« Reply #1 on: 02 November 2008, 15:05:21 »
                                    THANKS
Is the internal lever "loose" with no resistence when pulled? :-?
Can you see anything of the cable? :-?
« Reply #2 on: 02 November 2008, 15:12:40 »
As for coolant capacity of your 2.2 it is:
9.4 ltrs for a Manual Box  OR
9.2 ltrs for a Auto Box   :y :y :y
« Reply #3 on: 02 November 2008, 15:23:13 »
                                    THANKS
If the bonnet release catch is loose from the cabin end, then you should be able to use vise-grips or similar on the barrel nipple at that end. If there is resistance but it still doesn't release the bonnet, thenyou may need an assistant to push down on the front edge of the bonnet while you pull the release lever.
PS Please turn your caps lock off ...... it's considered rude to SHOUT!  ;)  :y  :y  :y
« Last Edit: 02 November 2008, 15:23:29 by Andy_B »
andycab
  • llanelli
« Reply #4 on: 02 November 2008, 16:04:14 »
ok thanks,sorry about caps,
