Author Topic: Omega Ignition switch probs  (Read 1474 times)
ramsay
« on: 28 October 2008, 18:51:16 »
Hi folks,
Just wondering if someone out there can help! I am having to put in a new ignition switch into my Omega 2.5 turbo diesel 1998.
Does the multi-plug on the left-hand side of the column just pull out?
and what effect could this have on the immobiliser?
Any ideas gratefully recieved. I am sitting here with one car that will not start????!!!! >:(
Matchless
  • Nottingham
    • A white van
Re: Omega Ignition switch probs
« Reply #1 on: 28 October 2008, 22:41:19 »
To get the connector off the ignition switch you have to turn the key to position '1' then look for a hole in the side of the connector, it gives access to a latch inside which you have to press in with a small screwdriver to release the connector.
The connector has to be levered off the contact blades but it wont move until you release the latch.
Ignition switch is fastened to the steering lock housing by a grub screw.
ballcock50
  • South Wales
« Reply #2 on: 28 October 2008, 23:06:21 »
No there is a small screw to undo then it will slide across off a pin iirc. Tom
« Reply #3 on: 29 October 2008, 00:27:33 »
Guess pics would help with this one - anyone oblige?
Matchless
  • Nottingham
    • A white van
« Reply #4 on: 02 November 2008, 21:10:12 »
A guide with pics should appear in the Maintanence section in the next day or so.
