Author Topic: 99 T reg elite  (Read 2741 times)
sneakypenguin
  • Birmingham
  • Xbox gamertag MagicGinjaninja
    • 07 Volvo V70 T5
99 T reg elite
« on: 02 November 2008, 03:09:35 »
good morning everyone, new to these forums and omega's so a few quick questions if you don't mind.
First of all, just underneath the indicator stalk there's another stalk that I've only just noticed and haven't got the first idea what it's for!
Secondly, the previous owner changed the battery and didn't have the code for the radio, so anyideas how to get  it working again? will it be a dealer jobby?sadly there isn't a handbook and I've checked all the paperwork but alas no code  :(
thirdly, it's done around 78400 miles and i'm not sure if the cam belt has been changed so would it be worth changing and roughly how much should I expect to pay?
fourthly, the sat nav cd that came with is is well out of date, 1998 it says on the case iirc so how much will a new one set me back and will it work with the current system? it's all factory standard and no upgrades.
fith, what type of engine oil does it need?
I think that's all for now and thanks for reading!
« Last Edit: 02 November 2008, 03:28:56 by sneakypenguin »
07 Volvo V70 T5 SE ex police
eddie
  • Cardiff
Re: 99 T reg elite
« Reply #1 on: 02 November 2008, 05:18:49 »
Hi there and welcome..relative 'newbie' myself.
If the extra stalk you mentioned is on the right,I believe it may the steering height adjuster,pull towards you and the steering wheel will leap upwards, a little downwards pressure on the wheel will bring down whilst holding the stalk towards you.
As regards the Radio etc,Vx main dealers can get the code for you,at a cost=there may be other means that others may know of.
Cam Belt--if in doubt change it. At 78,000 miles it should have been done by now (around 60K).
Time for bed.
eddie
MutantCav
  • Gainsborough
Re: 99 T reg elite
« Reply #2 on: 02 November 2008, 05:35:53 »
Stalk is short stubby and no writing on will as said be steering wheel height adjuster...
Cambelt and tensioners...if in doubt get it done, tensioners tend to fail first...should be done every 40k so at 78k its due even if it was done at 40k, which it may well not have been...expect to pay about £300-350 (find somewhere that knows what their doing...Vaux main dealer will probably quote way more!)...shop around if necessary and get the waterpump changed at the same time
Codes...main dealer will charge between about £15-35 to get your car pass...this will have all your stereo and CD player codes as well as key codes etc etc...well worth having :)
« Last Edit: 02 November 2008, 05:37:36 by ShieldOfSteel »
unlucky alf
  • worksop, notts
Re: 99 T reg elite
« Reply #3 on: 02 November 2008, 09:57:03 »
pop the stereo out first & check that nobody has written the code on the stereo, ive found that on various occasions!. ;)
Re: 99 T reg elite
« Reply #4 on: 02 November 2008, 09:57:45 »
Like  mine!  :-?  :-?
unlucky alf
  • worksop, notts
Re: 99 T reg elite
« Reply #5 on: 02 November 2008, 10:00:43 »
yup i found it on my one i have now, mind you a crap grundig unit so got binned anyway ;D
Bandit127
Re: 99 T reg elite
« Reply #6 on: 02 November 2008, 10:05:56 »
If it's long with buttons, LEDs and 'Gold Cruise' written on it, it's an aftermarket cruise control.
Mine has it.
Re: 99 T reg elite
« Reply #7 on: 02 November 2008, 10:09:00 »
Mine has it.
Why would an aftermarket kit be fitted to a car that could so easily have an OE cruise fitted?  :-/
Re: 99 T reg elite
« Reply #8 on: 02 November 2008, 12:20:55 »
Mine has it.
Cruise was an expensive option, and a few years ago, not many Omegas being broken ;)
Re: 99 T reg elite
« Reply #9 on: 02 November 2008, 12:25:26 »
Of course not :)
wheel height adjustment
Need carpass, or try member here call Dave DND
Due every 40k or 4 years. Do it if unsure now. If you fancy having a go, a DVD is available from our shop (http://shop.omegaowners.com) for £3
Navteq - http://www.navigation.com/is-bin/INTERSHOP.enfinity/WFS/Navteq-NavteqEurope-Site/en_GB/-/GBP/ViewStandardCatalog-Browse?CatalogCategoryID=zGEKCggRxbMAAAEOk89tNDzd&ShowAllProducts=YES - newer discs are quite slow, the Carin is a very old system.
Vauxhall Semi Synth - dirt cheap on Trade Club as well ;)
« Last Edit: 02 November 2008, 12:26:42 by TheBoy »
Re: 99 T reg elite
« Reply #10 on: 02 November 2008, 13:07:30 »
Mine has it.
S'pose so :). Vx cahrge enough for it still, it's a £200 option on an Astra H even though it's just a £30odd stalk & a Tech II session. :-?
Re: 99 T reg elite
« Reply #11 on: 02 November 2008, 13:25:21 »
Mine has it.
£37 trade for the stalk, plus a £8 clutch switch if required, and programming 3 ECUs on Astra-H
Re: 99 T reg elite
« Reply #12 on: 02 November 2008, 13:26:09 »
Mine has it.
Mind you, much easier to swap the stalk on Astra-H than it is on an Omega....
sneakypenguin
  • Birmingham
    • 07 Volvo V70 T5
Re: 99 T reg elite
« Reply #13 on: 02 November 2008, 17:39:42 »
thanks for you help and advice everyone, much appreciated. got the stero out but no code  :( so think it's going to be a dealer job. from what i've read i'm also going to need a code for the cd autochanger aswell so hopefully the dealer should have it on a computer somewhere ::)
Re: 99 T reg elite
« Reply #14 on: 02 November 2008, 17:41:39 »
Is on the carpass. Dealers charge between £15 and £50 for this, so ring a few dealers ;)
