Author Topic: Vectra v6 is it...  (Read 1828 times)
Recovery_Russ
Vectra v6 is it...
« on: 01 November 2008, 13:32:26 »
the same engine and does it suffer the same faults as the omega version?
Cheers
Russ
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Vectra v6 is it...
« Reply #1 on: 01 November 2008, 13:34:59 »
its the same engine but.....
has metal cam covers for a start so when breathers get blocked it blows the rear crankseal thus destroying its clutch! as i learnt!
also being the vectra suffers from a fair few electrical faults!
its the same block but has different inlet manifold, different oil sump as its FWD mounted and a few other little differences
jimbobmccoy
  • outer london
« Reply #2 on: 02 November 2008, 08:55:59 »
also mounted/crammed in the wrong way, makes it "interesting" to work on or even service. Makes you smile  when you put your foot down tho.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #3 on: 02 November 2008, 12:07:46 »
yes spark plugs are rather interesting to change especially the rears!
nah tbh 3.0 Miggy is quicker handles better too and sounds better!
Recovery_Russ
« Reply #4 on: 02 November 2008, 15:06:32 »
Ah ok, that doesn't answer my thoughts, i thought it might have a leaking cam cover as its got a bit of an annoying hesitance/misfire under acceleration, i'd say its more of a hesitannce actually. Any ideas?
Any one got a 3.0 manual elite forsale?
« Last Edit: 02 November 2008, 15:07:50 by Recovery_Russ »
Omegatoy
  • UK
« Reply #5 on: 02 November 2008, 21:13:17 »
what has to come off to change the rears mate, got to do one soon!!! ;)
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« Reply #6 on: 02 November 2008, 21:46:01 »
Indeed...  I've heard of quite a few V6 SRI's (Vectra B model's) just spontaneously catching fire on the drive without being driven.
Humbugs...
« Reply #7 on: 02 November 2008, 21:54:30 »
Some friends had a N reg one and had all manner of grief with it when it was new. Including fires IIRC.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #8 on: 03 November 2008, 07:28:33 »
Omegatoy,
The whole inlet manifold needs to come off then that should give you the access you need! few hours of undoing torq nuts and your in!
Recovery Russ
They do suffer rocker gaskets oil down the plugs! usually smokes aswell as hot oil melting onto manifold!
Clean the Idle Air Valve and unblock the crank breathers and look into the 3 pipe mod!
Recovery_Russ
« Reply #9 on: 03 November 2008, 12:44:28 »
Omegatoy,
Recovery Russ
Ok will do, thanks but on your first note, it appears the inlet manifold is in 3 parts a centre peice and then a piece either side which looks easily removeable to get at the plugs, just a 3 torx and 6 jubilee clips(securing side sections to center section  if you know what i mean)
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #10 on: 03 November 2008, 16:22:51 »
yes inlet manifold is fairly easy to get off! just time consuming!
EGR Valve and throttle cable and all the vac leads need to be removed too!
what you got then a V6 SRi or a GSi?
S13 ELC
« Reply #11 on: 03 November 2008, 18:50:37 »
cooling fan harness has been known to chaff through, and the battery back up siren behind the wing is known to start fires
Recovery_Russ
« Reply #12 on: 04 November 2008, 18:39:44 »
Neither, a CDX with full leather, climate, cruise etc :y
