Author Topic: heating problem  (Read 1293 times)
bobbertbear
  • perth
    • 04 omega 3.2 ex plod
heating problem
« on: 04 November 2008, 19:05:06 »
my mate has a t reg estate that i sold him,after i had done an engine change from 2.5 to 3.0 as the big ends were gone in the 2.5 when i got it,i had the car away to bristol on fri night an it was not very warm in the car,would it be the hbv as the temp never got high,sat around the 90 mark,but all seemed ok with water pipes apart from one of the pipes from the valve,seemed to be warm instead of really hot.
Re: heating problem
« Reply #1 on: 04 November 2008, 20:11:51 »
Bypass valve vac feed or the bypass valve connected wrongly....
Or the heater matrix needs a flush
« Last Edit: 04 November 2008, 20:12:08 by Mark »
bobbertbear
  • perth
Re: heating problem
« Reply #2 on: 04 November 2008, 20:15:15 »
where should the vac feed be connected to?
Re: heating problem
« Reply #3 on: 04 November 2008, 20:19:42 »
Connects to here:
Its the right hand pipe
bobbertbear
  • perth
Re: heating problem
« Reply #4 on: 04 November 2008, 20:24:44 »
thats the one crossing the heater pipe then,i think thats where its connected to as when i did the engine change i had my own mig next to it to check pipes in the right place
Re: heating problem
« Reply #5 on: 04 November 2008, 20:27:57 »
Its also possible to connect the water pipes to the bypass up wrong to.....
