Author Topic: Brakelight Check / Locked Gear Selector  (Read 2923 times)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« on: 04 November 2008, 18:50:58 »
Hi all ,
The other day the gear selector wouldn't release when i put my foot on the brake .... but it did release after a few pushes of the pedal ....
It done the same tonight in my drive whilst going to work and i noticed the brake lights wern't coming on  :-/ ..... untill it did release .
Is this a faulty brake switch or lock switch on the selector ....... i dont fancy getting stranded somewhere with a gear stick that wont move  :-/
Thanks
« Last Edit: 04 November 2008, 18:51:45 by Mark38 »
bobbertbear
  • perth
    • 04 omega 3.2 ex plod
Re: Brakelight Check / Locked Gear Selector
« Reply #1 on: 04 November 2008, 19:08:54 »
i would say the brake light switch isnt adjusted properly so you have to push the pedal further down for the switch to work therfore letting the gearstick release,either that or the switch is on its way out.
Proz
« Reply #2 on: 04 November 2008, 19:22:15 »
Ive sat in the car and tried to get it to do the same thing  .
When it releases it works fine ie just the gentlist push on the pedal and you can hear the click as the lock releases.... it was only tonight that i noticed the brake lights wernt shining on the wall on one or two pumps on the pedal hence i think it may be the brake switch ..... my other concern is that i dont have brakelights when im driving or would that cause the display to warn me of brakelight failure  :(
« Reply #3 on: 04 November 2008, 19:36:10 »
I would have thought you would get the "brakelight" check message on the display. Have you checked the fuse :-/
« Reply #4 on: 04 November 2008, 19:38:22 »
Just a thought. Is the brakelight switch wired in series with the lock switch under the gear selector lever :-/
« Reply #5 on: 04 November 2008, 19:41:55 »
Change the brake light switch mate, they don't cost too much. I had the same problems, sat at traffic lights in Park & not being able to shift out of it, it's amazing how popular you become with those in the queue behind you. ;D  ;D  ;D Just make sure you adjust it correctly when you fit it though, or you don't get cruise ...... apparently  ::)  ::)  ::)  :y  :y
« Reply #6 on: 04 November 2008, 19:43:36 »
Hi all ,
Thanks
If that happens pop the cover and shroud round the gearlever and release the lock switch manually. Easy enough done :y
« Reply #7 on: 04 November 2008, 19:45:40 »
brake switch.
Proz
« Reply #8 on: 04 November 2008, 20:33:39 »
Ahh that will explain why my cruise stopped working then worked later in the day  :y
Cheers
Proz
« Reply #9 on: 04 November 2008, 20:38:02 »
Hi all ,
Thanks
I did have a go at pulling up the shroud and cover but wasnt sure where or how hard to pull  :-[
« Reply #10 on: 04 November 2008, 20:38:06 »
Cheers
I think the fitting of a new brake light switch is covered in a 'how-to' some where in the forum. They more or less self adjust if you do it right .......  :y
« Reply #11 on: 04 November 2008, 20:39:35 »
A yellow lever to the left(?) of the shift lever.
Proz
« Reply #12 on: 04 November 2008, 20:40:11 »
Cheers
Ok thanks all ..... i will have a look around for the how to and see about a new switch  :y
Proz
« Reply #13 on: 04 November 2008, 20:41:56 »
I didnt get that far ..... i couldn't get the gear lever shroud or black plastic to come out ..... but then i didnt really pull too hard in case i broke something  :-[
« Reply #14 on: 04 November 2008, 20:45:17 »
They do just pull out  :y, I pull the rear our first.
