Author Topic: 2.5 V6 Facelift Thermostat Change  (Read 1112 times)
Jimmy Jerms
  • Kent/London Border
« on: 03 November 2008, 20:02:31 »
Can anyone advise on how to change the thermostat on my 2.6 V6 :-/
Re: 2.5 V6 Facelift Thermostat Change
« Reply #1 on: 03 November 2008, 20:05:01 »
Plenum off
Inlet/injector assembly off
Black inlet bridge off
Top hose off
Coolant transfer pipe bolt off (b@stard to get to! :D )
Seperate pipe from stat
Stat bolts out
Remove stat housing, clean mating faces, and replace as you removed :y
Kaycee
  • Doncaster
« Reply #2 on: 05 November 2008, 08:23:46 »
would i be right in saying the 3.2 is the same and the dealer says i must by complete part stat and housing is that correct
Thanks
There is a tide in the affairs of man if taken at the flood will lead on to greater things
« Reply #3 on: 05 November 2008, 09:03:52 »
Thanks
Yes, best bought here:
http://cgi.ebay.co.uk/Vauxhall-Thermostat-O-Ring-V6-90502201-Omega-VectraB_W0QQitemZ200271338776QQcmdZViewItem?hash=item200271338776&_trksid=p3286.c0.m14&_trkparms=72%3A1301%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
