Author Topic: v6 plenum question ..  (Read 3640 times)
v6venom
  • nr wareham dorset
  • banned due to bad trader references
« on: 30 October 2008, 23:31:30 »
another random question but ill crack on anyway .... :D
when i finally get the 3tr motor in my car id like to use the longer type plenum is it a straight swap over / or even possible ?
as both omegas i have now have the short version ??
also am i right to presume its the facelift models that have the longer item? lastly what price can i expect to pay for this ?
thanks in advance al :)
« Last Edit: 30 October 2008, 23:32:26 by v6venom »
Re: v6 plenum question ..
« Reply #1 on: 30 October 2008, 23:35:19 »
thanks in advance al :)[/b]
Mini face lift on i think. Mine is a 3.0 miniface lift and has a long plenum.
v6venom
  • nr wareham dorset
« Reply #2 on: 30 October 2008, 23:37:06 »
swift reply thanks andy ...
although a mini facelift now im confused whats the difference to a facelift then ?? :-/
« Last Edit: 30 October 2008, 23:37:29 by v6venom »
« Reply #3 on: 30 October 2008, 23:39:30 »
Mini face lift is the term generally used for the last of the PRE face lift cars, those that have solid head restraints, radio controls on the steering wheel and other things that I can't now remember. ::)  :y  :y  :y
« Reply #4 on: 31 October 2008, 08:39:23 »
And long plenums on 3 Lit!!
v6venom
  • nr wareham dorset
« Reply #5 on: 04 November 2008, 15:42:38 »
can anyone confirm these will be a direct fit to my car which is currently fitted with the shorter version ????
after looking at a few pics im thinking the throttle cable would need to be replaced minimum  ?? :-/
« Reply #6 on: 04 November 2008, 15:59:28 »
It also requires
The two throttle heater coolant pipes
Idle control valve air pipe
Multiram switch unit to throttle body air ducts.
Other than that its a straight swap
« Reply #7 on: 04 November 2008, 16:15:43 »
is it not worth going for the later 3.0 engine anyway? Rather than retro fitting a newer plenum on a older 3.0?
PhilCavSRi130
  • Stone,  Staffordshire
  • GRIFFIN POWER!!
« Reply #8 on: 04 November 2008, 16:43:38 »
While we're discussing the longer plenum set up... can anyone tell me why they changed them from the shorter ones and the benefits?? I've looked at swapping mine on the 2.5 for longer ones as i feel they look better than the short ones. Might not be an issue to some but i like to have a good looking engine bay along with the rest of the car. Finishes the car off when your at a show, cant have mint body and interior and a mess under the bonnet lol.
MutantCav
  • Gainsborough
« Reply #9 on: 04 November 2008, 16:45:17 »
Got one or 3 here with the bits you will need...£50 plus p&p or a mini facelift 3.0 v6 engine complete and delivered for £380...
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #10 on: 04 November 2008, 16:49:46 »
got better low down torque according to markey mark
V8!!!!
v6venom
  • nr wareham dorset
« Reply #11 on: 04 November 2008, 16:53:07 »
cheers for the replys guys .....
ref multi rams arent they already inplace ??
also mutant cav i already have a replacement 3 ltr which will be stripped and rebuilt over winter, i do however need some longer plenums but at this time ill hold on them due to watching my pennies .....
ngrainqey
  • rotherham
« Reply #12 on: 04 November 2008, 16:57:21 »
3.0 long plenium isnt the most expensive of things.
can get you a cheap one for incase i dont want it?
i'v got a 2.5 but it's getting the 3.0 inlets and stuff
btw as far as i know the multirams are the same but you'll need the shorter pipes which i might have (have to check)
« Last Edit: 04 November 2008, 16:58:45 by grainqey »
V8!!!!
« Reply #13 on: 04 November 2008, 17:16:13 »
3.0's are better with extented plenum, 2.5's don't need it, extended bit allows for  better airflow iic  :-/
« Last Edit: 04 November 2008, 17:16:27 by tunnie »
mahony
  • london
    • omega elite 3.0
« Reply #14 on: 04 November 2008, 17:39:33 »
The longer plenums were fitted at mini facelift,they where one of a number of improvements to the 3.0 engine, longer plenums give better low down torque,also at the same time the ignition timing and oil circuits where modified, also the engine block was made from composite graphite iron which reduced the noise of the engine,last but not least the auto box had a modified torque converter for better acceleration.
Page created in 0.1 seconds with 16 queries.
