Author Topic: anyone help  (Read 1242 times)
ianboyo
  • Somerset
anyone help
« on: 05 November 2008, 17:50:07 »
hello i have a omega 2.5 s reg have a water leak back of engine has anyone have some idea what it could be possibly the Heater valve  any help would be greatful thanks  :y
« Last Edit: 05 November 2008, 17:51:12 by ianboyo »
Re: anyone help
« Reply #1 on: 05 November 2008, 17:51:08 »
HBV is a likely candidate...
ianboyo
  • Somerset
Re: anyone help
« Reply #2 on: 05 November 2008, 17:53:03 »
thanks james thought it might be that, do they generaly pack up then ?would that coase a water leak.
Richie London
  • heathrow
Re: anyone help
« Reply #3 on: 05 November 2008, 17:58:47 »
mine did, didnt know it was leaking till had a good look round. bstrd of a job i thought, cut me hands to pieces changing it :( :(
Re: anyone help
« Reply #4 on: 05 November 2008, 18:36:01 »
Very common problem. not expensive (around £30 iirc). a bit fiddly to get at but no technical knowledge or special tools required. :y
I,m sure there is a guide in the relevant section.
Re: anyone help
« Reply #5 on: 05 November 2008, 19:06:07 »
There are a few things that can cause it, but HBV is most common.
Bandit127
Re: anyone help
« Reply #6 on: 05 November 2008, 20:04:53 »
It was a HBV on mine. Used to come up with a coolant level warning about twice a week.
I lived with it for a while. You can carry pre-mixed 50% coolant. But if you're a bit lazy like me you could alternate top ups between neat water and neat antifreeze. Either way, you must keep whats in the system at a 50% mix.
If it is HBV, it could well be dripping on your DIS pack which could get expensive and a difficult job to do.
It's a tricky job purely because it's an arse to get to.
There's a guide in the maintenance section...
