Author Topic: heater, climate control  (Read 948 times)
big_lebowski
« on: 06 November 2007, 12:44:01 »
Hi hope someone can help
having a problem with the c/c, the fans would not work at all the other day but came to live later that day but when I turned the engine off the fans continued to operate.
They ran the battery flat, I have charged the battery so that is now fine and the car runs fine but I have had to remove the fuse for the fans to stop them running.
The passenger side of the omega runs cold are constantly and the driver side hot air constantly also.
what could be the problem?
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
Re: heater, climate control
« Reply #1 on: 06 November 2007, 12:49:11 »
Probably be better to post this in the 'Omega General Help' section as the clever chaps don't always spend much time in here. However, if your thirsty or hungry, Nickbat is serving lunch in the Nag's Head.  ;D
[size=24]        [/size][/b]
Bo Bo
  • Coventry
« Reply #2 on: 06 November 2007, 12:52:05 »
It sounds like your heater fan regulator might have blown.
It's situated behind the glovebox & is easy enough to replace although a bit fiddley.
Check the passenger side scuttle drain to see if it's blocked.
« Last Edit: 06 November 2007, 12:59:29 by paulmccristall »
