Author Topic: Servicing  (Read 2483 times)
garbage456
  • Carshalton, Surrey
Servicing
« on: 05 November 2007, 20:03:23 »
Just bought a second hand Omega anyone got any ideas tips for servicing, is it better to go to vauxhall than an independent and what are the differences in tests/tasks done and costs please?
Thanks in advance.
Re: Servicing
« Reply #1 on: 05 November 2007, 20:06:30 »
Do it yourself ;)
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
Re: Servicing
« Reply #2 on: 05 November 2007, 20:06:43 »
Thanks in advance.
Go to vauxhall and buy genuine parts to service it, and have a go youself, there's plenty of guides in the maintence section to help you along :y
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Servicing
« Reply #3 on: 05 November 2007, 20:08:56 »
Thanks in advance.
and even better by getting or accessing a trade card for discounts.... :y
garbage456
Re: Servicing
« Reply #4 on: 05 November 2007, 20:29:52 »
Do it yourself ;)
It was more a case of I want someone else to check it to see if everything is ok.
Dave-C
  • Staffordshire
  • The Old Girl
Re: Servicing
« Reply #5 on: 05 November 2007, 20:51:59 »
Thanks in advance.
Where are you??
Re: Servicing
« Reply #6 on: 05 November 2007, 21:06:23 »
Main thing is to check when the cam belt was last changed bearing in mind it needs doing at 40k/4yrs and that both the belt and tensioner pulleys must be changed. If there's any doubt get this done ASAP.
Other common issues are to clean out the crankcase breathers, keep an eye out for coolant leaks and check the coolant is not contaminated with oil. Do any routine servicing that needs doing (we would recommend changing the oil more regularly than the dealer service intervals. every 3-4k is ideal). Coolant needs changing regularly as it can corrode the oil cooler if it is allowed to get old. It's worth changing the automatic transmission fluid and filter if there's no recent history of this having been done (it's not a service task according to VX but worth doing if the car has covered a fair mileage).
Have a read through the FAQ and maintenance guides as they cover all the common issues.
garbage456
Re: Servicing
« Reply #7 on: 06 November 2007, 13:13:22 »
thanks
garbage456
Re: Servicing
« Reply #8 on: 06 November 2007, 13:56:43 »
Just got a quote for a service around £300 for the standard service and £440 for the cambelt change service, argghhhh, i need to re mortgage my house.
Re: Servicing
« Reply #9 on: 06 November 2007, 13:59:46 »
So, subtract 300 from 440, that's 140 quid for a cam belt, which is a bargain. Do the rest yourself :y
ians
  • Reading
Re: Servicing
« Reply #10 on: 06 November 2007, 14:02:31 »
I don't think the 440 includes the regular service.. ::)
Are these main dealer prices?
Re: Servicing
« Reply #11 on: 06 November 2007, 14:04:37 »
I think you're probably right  ;)
Sounds like we need a cambelt party again sometime.
Whereabouts are you located, garbage456?
garbage456
Re: Servicing
« Reply #12 on: 06 November 2007, 14:35:50 »
carshalton surrey
garbage456
Re: Servicing
« Reply #13 on: 06 November 2007, 14:37:23 »
main dealer yes
the way it was worded was 300 for the standard service and 440 for the both including cam belt change
