This evenings little jobs
Started by TheBoy, 20 September 2006, 21:07:53
Couple of quick jobs on MV6
Quick oil change, I'd let it go a little longer than normal, around 5k.
Also unblocked the washer pump gauze that had blocked yet again.
Was it me, or is it starting to get a little chilly in the evenings now....
QuoteCouple of quick jobs on MV6
Well done m8  :) there is a little chill in the air here in ashford
CaptainZok
Just supervised the apprentice changing the sec air injection rubbers and yes the evenings in Bolton are getting a bit nippy again. Its getting dark quick too.
TuBy's new whipping boy.
It is getting dark early now dark here between 7:30-8:00 pm now
Timbuk
Just changed the header tank and cap tonight as i never could get rid of all the gunk after changing the oil cooler last month, rest of the system is really clean now after numerous flushes, hows your looking TB, its been about the same time?
My header tank on Proj TB1 is fairly clean (I did get good one from scrappy but never fitted as original cleaned up nicely). Its defo stained slightly brown though, but doesn't look too bad at all...
Timbuk
QuoteWell done to you aswell Timbuk
Only a ten minute job, just thought it was easier to change in the end, think the oil contaminated the seal on the cap :(
The oil ruins the seal, so it leaks as soon as it starts to pressurise...
Timbuk
QuoteWhats up with cap ?
Seal has expanded and doesn't fit the cap properly
Exactly what happened to mine...
Timbuk
QuoteThe oil ruins the seal, so it leaks as soon as it starts to pressurise...
Yep, guess thats what happened, but it only started leaking today
