Author Topic: turns over but dont fire... for a while anyway  (Read 2457 times)
ronnieboy
  • birmingham
« on: 07 November 2008, 22:04:21 »
Thanks Paul for directing me here. Could anybody help with this problem with my MV6 2.6? The car runs fine, but occassionally when I go back to it it turns over but does not start. 10, 20 or 30 minutes later it starts and is fine againg for hours, even days and then the problem starts again. I have recently changed the oil cooler, and plugs. Could something here have been disturbed on the loom? Could it be petrol pump or immobiliser problem? Could it be the ignition key? I do not know where to start with this problem to be honest. i look forward to any feedback. regards Ronnie
Re: turns over but dont fire... for a while anyway
« Reply #1 on: 07 November 2008, 22:09:58 »
Crank Sensor..
there are different models be sure you get the correct one..
« Last Edit: 07 November 2008, 22:11:01 by cem_devecioglu »
ronnieboy
  • birmingham
« Reply #2 on: 07 November 2008, 22:13:34 »
It could be I did remove this to undo the oil cooler pipes at the oil filter end. I would have thought that the crank sensor would either work or not work but my fault seems to be intermittent. I will have a look at the sensor tomorrow aswell as other parts of the loom I may have disturbed. Thanks for the feedback, much appreciated.
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
« Reply #3 on: 07 November 2008, 22:18:18 »
Agree with Cem it on it way out - I  had same thing.
Then a non-starter.  :-/
« Last Edit: 07 November 2008, 22:23:23 by iggy21uk »
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
MutantCav
  • Gainsborough
« Reply #4 on: 07 November 2008, 22:21:17 »
No mate they do fail and can be intermittent when they are on their way out...mostly brings up a code 19 (not sure of relevant code for the facelift) but again not always...but almost certainly...crank shaft sensor on its way out...
ronnieboy
  • birmingham
« Reply #5 on: 07 November 2008, 22:22:54 »
Thanks I will look to pick one up from my VX dealer in the am. are they expensive to fit, and yes it is easy to remove from the block, but is it easy to disconnect the other end loom side?
Welung666
« Reply #6 on: 07 November 2008, 22:53:10 »
Easy enough to fit yourself :y
ronnieboy
  • birmingham
« Reply #7 on: 07 November 2008, 23:03:29 »
Thanks Lee. I check the plug at the top end first make sure I havent disturbed it when I did the oil cooler. I  did have to remove the injector rail plug for the oil cooler so stands a chance. I meant to say on my last post are they expensive to buy?
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #8 on: 07 November 2008, 23:06:35 »
if its the square/rectangle plug then around 40/45 pounds and 78ish for the oval one (oval ones for later one)
V8!!!!
ronnieboy
  • birmingham
« Reply #9 on: 07 November 2008, 23:11:55 »
ok good news. I will post an update tomorrow with progress and hopefully problem will be cured. I would like to thank everyone for their feedback with this problem. Kind regards Ronnie
« Reply #10 on: 08 November 2008, 09:06:45 »
Its an easy job to do, made even easier by reading this :y
http://www.omegaowners.com/forum/YaBB.pl?num=1174321688
ronnieboy
  • birmingham
« Reply #11 on: 08 November 2008, 09:42:53 »
Pete, thanks for the info. Off to VX today to get stung. Will fit it later in the rain get soaked through but in the knowledge that my car is fixed. Definately the cheapest option made possible with the help from you guys. Thanks to everyone for such helpful feedback.
Welung666
« Reply #12 on: 08 November 2008, 10:35:45 »
You should come to sunny Dudley Ronnie, not raining here and the sun is shining :D
« Reply #13 on: 08 November 2008, 12:05:26 »
nobody mentioned the pedal trick to confirm?
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
ronnieboy
  • birmingham
« Reply #14 on: 08 November 2008, 18:22:49 »
Guys update for you all. Got crank sensor from VX £50+ a free pen for my nipper... who says VX dealers are are bad!! Sunny Dudley it was did the job, rerouted cable away from exhaust as much as possible. Low and behold took car for one wicked hard drive, stopped at the garage, stopped at the cash till and it started every time. Thank you to all who left feed back and helped me out with this. Hope the fault is now cured, but no doubt time will tell. Great site i will be hooked on this now!
