Author Topic: Will parts fit?  (Read 1625 times)
manny
  • bromorough.Wirral.
Will parts fit?
« on: 08 November 2008, 21:27:12 »
Im going to change my steering tie rods and also the roll bar drop links.Are the the same on all omegas?Or is the mv6 different?
2001 OMEGA MV6
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Will parts fit?
« Reply #1 on: 08 November 2008, 21:40:15 »
sure droplinks are all the same mate :y
manny
Re: Will parts fit?
« Reply #2 on: 08 November 2008, 21:41:40 »
What about the Track rod ends/tie rods?
2001 OMEGA MV6
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Will parts fit?
« Reply #3 on: 08 November 2008, 21:47:13 »
I am pretty sure track rod ends etc are the same
Re: Will parts fit?
« Reply #4 on: 08 November 2008, 22:44:58 »
honest answer is dont know. But, i know wishbones are the same across the range so i dont see any reason why the track rod ends should be any different.
Fairly sure from looking at various web sites the drop links are the same but also i dont recall anyone swapping to mv6 suspension having to change drop links?
« Last Edit: 08 November 2008, 22:46:25 by chrisgixer »
Re: Will parts fit?
« Reply #5 on: 08 November 2008, 22:58:01 »
Same :)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: Will parts fit?
« Reply #6 on: 08 November 2008, 23:32:05 »
what robg said :P
all the front/rear suspension components are interchangeable. only exceptions could be going from prefacelift to facelift and also the estates with self leveling rear struts
« Last Edit: 08 November 2008, 23:32:27 by grainqey »
V8!!!!
dieseldean
  • chesterfield
Re: Will parts fit?
« Reply #7 on: 08 November 2008, 23:44:42 »
but if suspension is lowered then the camber will change
Albatross
  • Bedford
  • An LSD & an S2000!
Re: Will parts fit?
« Reply #8 on: 09 November 2008, 09:48:57 »
All the parts are the same with the exception of springs and shock absorbers.
Camber is not affected that much and is still within tolerance.
Checked with WIM and my very trusted stealer's EPM guide about two months ago when I changed my facelift Elite to brand new MV6 suspension and had it fitted by Tony at WIM.
« Last Edit: 09 November 2008, 10:08:01 by Albatross »
