Author Topic: Two quick questions  (Read 3074 times)
bighed
  • Shropshire
Two quick questions
« on: 07 November 2008, 23:00:55 »
Hi guys, as above two questions, easiest one is what does the grid on the back side window(s) that says alarm in middle do?  :-/ there is two little sensors at either end too.
Next 1, i have got some bulbs that have gone on my climate control panel.  :( Anyone know the vaux code for these and how i remove the trim panel?
Oh and a pic of the reverse of one so can see just how many bulbs have blown would be a bonus..... ::)
Thanks in advance. Jon  :y :y :y
« Last Edit: 07 November 2008, 23:02:14 by bighed »
Re: Two quick questions
« Reply #1 on: 07 November 2008, 23:05:49 »
The panels are glass break sensors ...... surprisingly! ::) :y :y
bighed
  • Shropshire
« Reply #2 on: 07 November 2008, 23:17:32 »
thats what i thought but seem pointless if there are interior sensors anyway?
MutantCav
  • Gainsborough
« Reply #3 on: 07 November 2008, 23:34:16 »
To remove climate panel...remove stereo...remove ashtray (unclip the ash tray itself giving access to the 3 screws holding it in place) then carefully reach into the stereo hole and up behind the wiring after a bit of searching you will find a thick solid metal bar...it pulls downwards to release the centre console bit...you can then access back of the climate controle :)
Cumbria
  • Southport. Merseyside.
« Reply #4 on: 07 November 2008, 23:41:00 »
http://www.omegaowners.com/forum/YaBB.pl?num=1162120610
Hi it shows how to replace the climate bulbs here.
bighed
  • Shropshire
« Reply #5 on: 08 November 2008, 00:51:20 »
brill thanks!
holtender
  • Suffolk
    • 2.5 CDX Facelift
« Reply #6 on: 08 November 2008, 00:56:06 »
If only I had received such detailed directions like that as a young and innocent 16 year old!!
bighed
  • Shropshire
« Reply #7 on: 08 November 2008, 13:19:05 »
Just looked at the how too and there are two types of bulbs on there. How would I know which ones I need? :-/
And it says there are only 5 bulbs???
Looks like about 4 of mine have gone but there are still a few working???  :-/ :-/ :-?
« Last Edit: 08 November 2008, 13:21:35 by bighed »
Richard A
  • Aldridge, West Midlands
« Reply #8 on: 08 November 2008, 17:47:42 »
While it's in bits replace the lot !!!
regards
richard a
p.s. take the old bulbs with you to the vx dealer
richard a
bighed
  • Shropshire
« Reply #9 on: 08 November 2008, 22:53:34 »
Thanks Richard A.  :y How much are these bulbs at the stealers? Can these be got off ebay? Does anyone know what they are called.
I think i recall hearing capped and capless about bulbs at one point  :-/ :-[
bighed
  • Shropshire
« Reply #10 on: 09 November 2008, 00:29:16 »
Anyone know?
 :-/ :y
Matchless
  • Nottingham
    • A white van
« Reply #11 on: 09 November 2008, 18:23:45 »
Ultrasonics wont work if you have the load net or a dog guard fitted so break glass detectors help protect the load area.
« Reply #12 on: 09 November 2008, 18:39:28 »
Glass break sensors.
5 bulbs in climate panel - 3 for backlights, 2 for illumination of buttons via lightguides. Auto indicator is LED, and reliable.  Change all 5 together, about £1 each from stealer iirc. Slightly cheaper from Farnells, but min £30 order. Forget the eGay.
Welung666
« Reply #13 on: 09 November 2008, 18:52:30 »
I need to do the bulbs in my CC, is it a bulb for the temp. readouts? Drivers side is dark on mine.
« Reply #14 on: 09 November 2008, 18:59:08 »
correct. Change all 5 at once.
