Author Topic: up.date from last night ??  (Read 1227 times)
mick-1975
  • nottingham
« on: 09 November 2008, 16:34:33 »
hi guys i need your help big time ,,
  what should of been an easy job has turned into a pain ,, :'( :(
  anyway had to take exhaust manifold off and found 2 bolts at the front snapped !!
 any ideas on how to get these out without takin the head of plz  :-[ :(  :y :y
  ths mick
« Last Edit: 10 November 2008, 12:07:56 by mick-1975 »
Abiton
Re: help needed
« Reply #1 on: 09 November 2008, 16:56:46 »
What engine?
mick-1975
  • nottingham
Re: help needed
« Reply #2 on: 09 November 2008, 16:58:02 »
What engine?
  its 2.0l estate
Abiton
Re: help needed
« Reply #3 on: 09 November 2008, 17:06:25 »
In that case it may be possible to sort out with the head on, but it'll not be easy if the studs have snapped flush, or sub-flush with the head alloy.
'Easy-out' type stud removers can work, but it is critical to drill the pilot hole really central.  They have been known to snap off compounding the problem.
I had just the very front one go on ours (immediately adjacent to the thermostat housing).  Eventually got it out with the aid of a very short electric drill and a special jig I made to ensure that the drill stayed on course.  T'was a struggle, but very satisfying to solve.
Tried easy-outs but gave up as I could 'feel' that I was about to snap one.  Re-tapping my newly opened hole was a delicate business too.
Jig available for loan, FOC; but IIRC it sits over the nearest other two studs, so you might have to remove/replace the other bust one before it could be of use. :)
Matchless
  • Nottingham
    • A white van
Re: help needed
« Reply #4 on: 09 November 2008, 18:11:24 »
If you can get some round bar which is a tight fit in the manifold bolt hole you can drill a 2mm (say) hole through it and use it as a drill guide.
You will need a good light and a mirror to centre the manifold hole on the broken stud (quite a bit of slop in the holes) then nip up a couple of nuts to hold it still. Insert the drilled rod and use it to drill a pilot hole in the broken stud. Be very carefull not to drill too deep, just through the stud and no more, as there is a water jacket behind the front stud.
Biggest problem you will have is getting a drill in there, space is tight, a 90degree drive might be necessary.
If the studs were already snapped then check that someone hasnt already tried to drill them out....
mick-1975
  • nottingham
Re: help needed
« Reply #5 on: 10 November 2008, 11:58:51 »
 :y  thanks everyone for the replys
   decided to take the head of last night around 8 , outside ,luckily in a car port and a light finished at around half 10,
  i dont think thats bad at all ,  anyway waiting to get head back now to start putting it back together
 not lookng forward to it at all  >:(      should be back on road good as new real soon ,
 i shall keep you posted
  :y :y
Page created in 0.022 seconds with 20 queries.
