Author Topic: help !  (Read 3107 times)
seprim
  • Ramsgate, Kent
  • Omega 2.6 V6 24 2003 Auto LPG
help !
« on: 10 November 2008, 10:58:07 »
I have just changed the cam belt and tensioners, idler and aux belt and water pump. I reassambled the bits and refilled the coolant level in the header tank to cold level. It started fine and although tappety it revved well.
As i had the plenum off i took advantage of rerouting the coolant via the lpg vapourisor before it went into the HBV. . . .
I took the car out for a gentle spin and halfway down the road the spanner/car orange warning light came on and shortly after the car stalled. i managed to restart and drive back home a little way and it happened twice again before i could get it home.
I am unsure where to go from here - any ideas ? :-/
Jet penguin ----
jonathanh
  • coventry
Re: help !
« Reply #1 on: 10 November 2008, 11:18:04 »
step 1, find out the fault codes.  look under the maintaince guide for paperclip test/pedal trick.  you want the latter on the 2.6
step 2, post the fault codes here and we can give you more help
chances are, it is something you disturbed when doing the work
Is it still running smooth?  i.e. is there any chance the belt could have slipped?
Re: help !
« Reply #2 on: 10 November 2008, 11:22:52 »
As above... But as a guess I'd say you've probably got an air leak around the plenum.
seprim
  • Ramsgate, Kent
Re: help !
« Reply #3 on: 10 November 2008, 11:23:47 »
runs lovely and smooth - i dont think the belt has slipped . . .
will run diagnostics from my hungarian thingy from fleabay - brb
Jet penguin ----
seprim
  • Ramsgate, Kent
Re: help !
« Reply #4 on: 10 November 2008, 15:18:15 »
im having difficulty using the diagnostic tool - its called TIS 2000 and i havent the foggiest how to get a diagnostics readout. .
do i need to have the engine running ?
which part do i select ?
Jet penguin ----
Re: help !
« Reply #5 on: 10 November 2008, 15:32:10 »
Just floor the throttle and brake and turn the ignition on and count the ECU light flashes.
seprim
  • Ramsgate, Kent
Re: help !
« Reply #6 on: 10 November 2008, 15:46:58 »
10 3 2 5   ?
Jet penguin ----
Re: help !
« Reply #7 on: 10 November 2008, 15:47:48 »
Your car has a diagnostic built in, to a point, use the pedal trick as above. Foot on brake, gas pedal to the floor, turn on ignition to position 2. Do NOT fire the engine obviously. The car spanner symbol will flash. Constant flashing, no codes stored, 10 flashes is zero. 4 digit code only. Reads the engine ecu so dont worry about the your code reader for a minute. Get the car running first imho.
Video in link,http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
Codes here.http://www.obd-codes.com/trouble_codes/
 Hth
seprim
  • Ramsgate, Kent
Re: help !
« Reply #8 on: 10 November 2008, 15:50:01 »
thx chrisgixer  :)
Jet penguin ----
seprim
  • Ramsgate, Kent
Re: help !
« Reply #9 on: 10 November 2008, 15:51:54 »
have i killed the knock sensor ?
Jet penguin ----
Re: help !
« Reply #10 on: 10 November 2008, 15:52:36 »
crank sensor. Get genuine only. Pattery last weeks.
seprim
  • Ramsgate, Kent
Re: help !
« Reply #11 on: 10 November 2008, 15:58:54 »
did i misread ? u said crank sensor ? not knock sensor :) . . .then get genuine - so i buy a vx product only - ok then you said "pattery last weeks " what does that mean please ?  :-[
Jet penguin ----
Re: help !
« Reply #12 on: 10 November 2008, 16:08:21 »
Oh bugger. My mistake. I missread.
Knock sensor as you say. Probably got the wire trapped. Not had this problem myself. Maybe other members can help.
Sorry to mess you about.
seprim
  • Ramsgate, Kent
Re: help !
« Reply #13 on: 10 November 2008, 16:09:53 »
no worries :) thx for your help
Jet penguin ----
Re: help !
« Reply #14 on: 10 November 2008, 16:27:10 »
0325 - Knock sensor 1, drivers side.
It connects to the loom on the cable tray on the front of the cambelt cover.
Make sure its connected ok and make sure the loom is not near the aux belt (it can get damaged). Other possible is that its been trapped under the aux belt tensioner casting.
