Author Topic: how to pair radio and display?  (Read 3683 times)
sneakypenguin
  • Birmingham
  • Xbox gamertag MagicGinjaninja
    • 07 Volvo V70 T5
« on: 08 November 2008, 00:27:27 »
good morning everyone, a little problem to test those grey cells of yours.
I've got a 99 omega elite (3.0 one), when i bought it the battery was changed and lost the codes for the raio/cd changer etc. Now, I got the codes through my local vx dealer, but can't see anywhere to put them in. Done a little research and, correct me if I'm wrong, I have to pair the radio to the display? How on earth do i do this? any help would be much appreciated!
« Last Edit: 08 November 2008, 01:11:28 by sneakypenguin »
07 Volvo V70 T5 SE ex police
Re: how to pair radio and display?
« Reply #1 on: 08 November 2008, 02:43:08 »
No pairing just input the codes into radio. What unit have you got :)
sneakypenguin
  • Birmingham
    • 07 Volvo V70 T5
« Reply #2 on: 08 November 2008, 02:51:21 »
it's the ccrt 700 head unit, the reason i was wondering about the pairing was nothing comes on the display about safe mode or anything.
UPDATE: Got the radio working (not a bad sound actually) but another question, does it show what station/frequency your listening too or is it just guesswork?
thanks
« Last Edit: 08 November 2008, 03:08:25 by sneakypenguin »
Welung666
« Reply #3 on: 08 November 2008, 08:29:24 »
The radio station should be displayed on your dash info panel.
« Reply #4 on: 08 November 2008, 10:38:13 »
does the rest of the display work, eg trip computer, time etc? if not, the backlight may be blown - 2 or 3 bulbs, dead easy to replace
sneakypenguin
  • Birmingham
    • 07 Volvo V70 T5
« Reply #5 on: 08 November 2008, 11:13:34 »
the display work's fine, no dead pixels and shows inst consumption, range etc, just wondering if i had to do anything to make it show on there
« Last Edit: 08 November 2008, 11:19:13 by sneakypenguin »
MickAP
  • South Derbyshire
« Reply #6 on: 08 November 2008, 12:42:57 »
If you don't get the problem solved try posting in the Omega electrical section, bet Dave DND will be along swiftly to give you the info.
Mick
« Reply #7 on: 08 November 2008, 16:27:19 »
So its purely radio/cd info that doesn't show? What about the Phone section of the display, does that show up right?
sneakypenguin
  • Birmingham
    • 07 Volvo V70 T5
« Reply #8 on: 08 November 2008, 22:18:23 »
As I say, the only things on the display are the mpg,outside temp (which is very optomistic), inst consumption,range etc, nothing on there refering to the radio or phone at all. doesn't bode very well does it? thanks for all your help btw
« Last Edit: 08 November 2008, 22:20:00 by sneakypenguin »
« Reply #9 on: 08 November 2008, 22:45:10 »
Can I ask a quick Q?  If is a half height display, and not the full height one?
MickAP
  • South Derbyshire
« Reply #10 on: 08 November 2008, 22:48:22 »
I only ever owned a facelift so don't know about what should be showing on your prefacelift's display. On my facelift it shows radio station or CD info, or when turned off the date I think.
Like I suggested post in the Omega electrical section you should get a swift answer there.
Mick
sneakypenguin
  • Birmingham
    • 07 Volvo V70 T5
« Reply #11 on: 08 November 2008, 23:00:27 »
at a guess I'd say it's a half height display, could do with a picture to say for certain
« Reply #12 on: 08 November 2008, 23:29:38 »
Right, so correct display.  Might be worth reseating radio, failing that, you'll need to get the meter out and check wiring
« Reply #13 on: 08 November 2008, 23:39:42 »
disconnect the battery for a while. Say 5 mins? I presume thats what TB means? Youll have to reset the one touch windows, hold the window up for a couple of seconds after closing, and hold the sun roof dial in, in each position to reset the sunroof. Hth
« Reply #14 on: 08 November 2008, 23:45:56 »
No, I meant reseating it in its cage.
Page created in 0.22 seconds with 16 queries.
