Author Topic: 2.0 GLS Auto - Immobiliser 1502 - No signal  (Read 3605 times)
unlucky alf
  • worksop, notts
Re: 2.0 GLS Auto - Immobiliser 1502 - No signal
« Reply #15 on: 12 November 2008, 23:33:33 »
couldnt tell you for sure as there is other things that may cause it, anyhow you say all the lights are coming on by the gear stick, was it doing this before?, the switch is adjustable so mght be an idea to get both 10mm bolts in & move the switch about & see if you can get the lights to function properly as it is adjustable, ive had the same problem when i first fitted my g/box & it was just adjustment so hopefully youll be o,k,,,,best of luck :y
X30XE
  • UK
    • 740i,728i,S320 & Disco
« Reply #16 on: 13 November 2008, 20:42:38 »
Still having no joy with this problem.  In key position two the fuel pump relay and injector relay can be heard rattling away to themselves, but when key turned to 3 - nothing.  Fault code is still logged as 1502 only.  But EML doesn't always flash after failed start like before, so could the stored 1502 code be no longer relavent?  :-/
Beginning to doubt gearbox connected to immobiliser issue.  No better in Neutral for starting (which appears to select ok, and says should start with in handbook).
Omegatitis : [in remission]
