Author Topic: Omega v6 DIS pack removal Pics  (Read 3905 times)
A1TNL
  • THATCHAM
« on: 08 November 2008, 18:21:21 »
Some pics of me removing my DIS pack from my omega v6 3.0
Maybe they can be used to as part of the guide for removal
« Last Edit: 14 November 2008, 08:30:17 by Auto_Addict »
Tafty
  • Liverpool
  • This week I am no longer the owner of a miggy!! :(
Re: Omega v6 DIS pack removal Pics
« Reply #1 on: 08 November 2008, 19:21:38 »
^^^^ Nothing showing am afraid :-?
Edit: Super job - showing now :y
« Last Edit: 08 November 2008, 21:15:52 by Tafty »
A1TNL
  • THATCHAM
« Reply #2 on: 08 November 2008, 19:38:34 »
could someone confirm the pics are showing ok now
Thanks
« Reply #3 on: 08 November 2008, 19:52:19 »
They are. :y
Pete Elite
  • Uxbridge, Middlesex
« Reply #4 on: 08 November 2008, 23:52:45 »
  That dispack is well shot :o.
 PS. Just for your info, it would be best in future to stick some rag or kitchen paper in the inlet manifolds in case you drop a bolt etc. down them :(.
eddie
  • Cardiff
« Reply #5 on: 09 November 2008, 05:31:53 »
Yikes! Thats one rotten Coil Pack,when I took mine out I had a problem telling it from the new one.
It is a bit easier if you clear all the bits away from the engine area though. I also removed all the wiper mechanism retaining screws to get that extra millimetre of clearance.
I must say that since I changed mine it is like having a new car,so smooth and punchy. I take the long way home just for fun now!
eddie
« Reply #6 on: 09 November 2008, 09:31:21 »
Yikes! Thats one rotten Coil Pack,when I took mine out I had a problem telling it from the new one. .......
Although mine wasn't quite as bad as that, mine had started to split due to corrosion of the coils.
A1TNL
  • THATCHAM
« Reply #7 on: 09 November 2008, 14:57:28 »
You are write with the kitchen paper, i did nearly lose a bolt
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #8 on: 12 November 2008, 22:26:22 »
just two points/questions....
how many torx bolts are there holding the dis pack on and also whats on the bottom of the dis pack? 6 plugs or what?
thanks (on about swapping mine thats all)
V8!!!!
« Reply #9 on: 12 November 2008, 22:32:50 »
There are 4 /torx bolts holding it, I used an 8 mm 1/4" drive hexagonal socket though as my Torx were too fat to fit.
Bottom? Not sure what you mean. You can see in the picture where the 6 HT leads plug into the DIS and at the end of the DIS not shown there's a 4? pin socket for the LT/ECU
ngrainqey
  • rotherham
« Reply #10 on: 12 November 2008, 22:33:48 »
the 4 pin sockety thing you mentioned is what i was after ;)
V8!!!!
« Reply #11 on: 12 November 2008, 22:36:42 »
Be aware that there are 3 different DIS packs fitted, and it's the 4? pin plug that's different .... I think :-/  :y  :y
I gave Vauxhall the Bosch number for my replacement, who price matched ..... errrrr .... someone else :y
bighed
  • Shropshire
« Reply #12 on: 12 November 2008, 22:37:25 »
Funny.... Just done mine today (pics on my help please post.) and mine was cracked although not that bad. Told its from failed hbv. Are u loosing coolant at all?? :y
ngrainqey
  • rotherham
« Reply #13 on: 12 November 2008, 22:41:36 »
lol... only  :P
what is with vauxhall and changing things... sometimes for the worse...
two crank sensors later which is like twice as expensive, 2 headlight adjusters.. later ones break..3 dispacks...and then the fact theres prefacelift minifacelift and facelift models...
can they not just let a miggy be?
V8!!!!
bth2bth2
  • sunny blackpool
« Reply #14 on: 13 November 2008, 12:32:09 »
hey...just looks like mine did !!!!
