Author Topic: Redex or not ?  (Read 2157 times)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Redex or not ?
« on: 13 November 2008, 13:01:59 »
On my next fill up should i use some Redex to clean some things out ?
I used the Tesco premium fuel on my last fill and found my consumption nose dived  :-/....
webby23
  • Nottingham
  • MV6
Re: Redex or not ?
« Reply #1 on: 13 November 2008, 13:15:13 »
Personally I find Redex over rated.
I use BG 44K which is in a can, costs 20 quid (from Formula 1 Autocentres) and is fantastic.
Engine alot quieter, fuel consumption reduced and a bit more power too.
Expensive, but noticable when used.
I think Redex is more psychological than actually effiecient.
« Last Edit: 13 November 2008, 13:16:43 by webby23 »
Re: Redex or not ?
« Reply #2 on: 13 November 2008, 15:08:15 »
There's no need to use anything unless you have a problem IMHO.
A shot of injector cleaner once a year might be beneficial but having said that my kit car got injectors from a scrap car with mega miles (It was an old school Volvo and it had worn out).
They did another 20k without any treatments in the fuel before I decided to have them flow tested and cleaned and they were still in spec and had a good spray pattern.
I believe Tesco super has quite a lot of Ethanol content which would explain the poorer fuel consumption or are you saying the consumption plummeted (more MPG)?
Proz
Re: Redex or not ?
« Reply #3 on: 13 November 2008, 15:22:49 »
I normally get maybe 27-29 mph just doing my normal routine , but after my problems with the dreaded code P0420 i filled up with the premium stuff and now my mid is reporting 23 mph and only 300 miles out of the tank .... car is going in to Vx for a new cat under the warranty ( not genuine but aftermarket as they said it would be £800  :o ) so will see if this sorts out this troublesome code  :-/
« Last Edit: 13 November 2008, 15:24:30 by Mark38 »
Moos3h
Re: Redex or not ?
« Reply #4 on: 13 November 2008, 18:52:17 »
All fuel system cleaners will have SOME benefit on a previously filthy system.  However, it's not going to have got like that from one tank of petrol (unless Tesco have a dodgy batch again).
More than likely the petrol you have is just old as RON decreases over time.
Redex can't hurt, £3.24 for a huge bottle (with 50% extra free) in my local Wilkos.
Cheers,
James
markomega25
  • Morden, Surrey, A3 gateway
Re: Redex or not ?
« Reply #5 on: 14 November 2008, 03:17:59 »
At the risk of opening up a long and well rehearsed debate about after market fuel additives:-
I have experimented with using pure Acetone (what most people recognise as being nail varnish remover) as an additive in my 19 year old motorbike. Dosage 50 to 60ml of pure acetone per 10 gallons.
Results:-
although these may be psychological, I do feel it has made the bike run smoother (FJ1200's do vibe a lot), and I am quite sure I get a few more mpg (5mpg more touring france for 2 weeks than the year before) although that could be down to many, many different factors. It has certainly not done any harm (a year in trials), although my bike is a carb fed fuel system without all the modern electric fuel gizmo's in a mega.
Do a google for "Acetone as a fuel additive", there's reams of talk about it, some sceptical some not. But I am sure Which magazine did a report on the aftermarket stuff like redex/STP etc and they found they made no difference at all to performance or mpg, although those tests were no doubt done on a clean engine. So as someone mentions above, a dirty fuel system might benefit quickly in the short term from a clean out.
Warnings:-
do not use acetone/nail varnish remover from a beauty store. For one it is vastly expensive; and 2, it contains moisturisers/softners such as lanoline for nails which will react badly with the combustion and produce nasty results in the internal fuel delivery system. If you are going to do this you must get 99% pure stuff.
I bought mine from this company below £8 per 5 litres, although postage was steep (highly combustable liquids in large quantities) so they phoned me to ask if i really wanted only 5 litres. So I bought 10 litres (economies of scale as the postage was the same for twice the amount etc.).
 http://www.allscotltd.co.uk/prodtype.asp?strParents=&CAT_ID=123&numRecordPosition=1
Someone on ebay is selling 500ml as here.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250306806761&cguid=1189496211d0a0e202c3d983ffe5f916
It has other usages too, paint stripper, general degreasing agent, sniffing (oops, did I say that!).
Some say that Acetone will degenerate rubber fuel hoses, but at the dilution used above it is very unlikely. Having said that I have not tried it in my omega yet..
Re Tesco Petrol. I have read that although most petrol is dispensed from the same tanks at each refinery, the refiners/wholesellers, add additives at the point of dispensing depending upon the buyers (i.e Tesco's or your local independants) requirements. And the reason why Tesco's petrol is cheaper is that they order less additives. So some additives to Tesco's petrol might give improvements in mpg, but Redex I would say is a very expensive way of doing it.
Not to say that Tesco's petrol is bad, but I read that BP Ultimate for example uses Acetone as one of its additives to improve combustion (Acetone breaks down the molecules or surface tension in petrol thereby theoretically giving improved combustion). Which may be why BP ultimate is regarded quite highly by some (although again you are paying way over the odds for BP to add in their requested additives).
Profit at every stage!
You pays your money and takes your choice.
By the way I believe any change in petrol and its additives takes some time for an Omega's brain to work it out, so any improvement that these additives may have are certainly not instantly recognisable. May need a few hundred miles for the sensors to react and the brain to adjust - but I might be completely wrong.
Mark
« Last Edit: 14 November 2008, 03:53:32 by markomega25 »
MikeDundee
  • Costa Del Peckham
Re: Redex or not ?
« Reply #6 on: 14 November 2008, 06:47:19 »
Have always avoided the supermarket fuel, never use it, only use BP :y
silver shark
Re: Redex or not ?
« Reply #7 on: 15 November 2008, 11:40:31 »
i used tesco petrol and the 3l elite performance went down hill , filled up next time in local texaco (a bit dearer) and she was back to normal.steer clear of super market petrol! :y
Re: Redex or not ?
« Reply #8 on: 15 November 2008, 13:10:04 »
In the MV6, it gets a dose of forte gas treatment every year (i reckon the forte stuff is better than redex).
The tractor gets shot of diesel redex (coz its cheap!) every few tankfuls, or a double shot every tank if  have to use supermarket fuel.
