Author Topic: Reverse Lights  (Read 1411 times)
Sabs
  • Epsom, Surrey
Reverse Lights
« on: 08 November 2008, 12:34:14 »
Hello Guys
Im in need of more of your help yet again. Sorry
CAR: OMEGA ELITE 2.5 AUTO MINI FACELIFT
My reverse lights arent working.  Changed the bulbs and checked the fuse.  Now because its an auto, i assume it has no reverse light switch, so im a bit baffled as into how i go about sorting this out?
thanks
Saboor
Albatross
  • Bedford
  • An LSD & an S2000!
Re: Reverse Lights
« Reply #1 on: 08 November 2008, 18:26:27 »
Have you tried to clean the gear selector inside the centre console with contact cleaner? Don't use WD40, use proper contact cleaner from Maplin. Costs about £2.
bigall
  • merseyside
Re: Reverse Lights
« Reply #2 on: 08 November 2008, 19:32:01 »
by any chance has the omega got a towbar with electrics????????
I drive a moneypit Omega - at least its comfortable!!!!!  200k approaching rapidly!!!!!!!!! "") (must change oil soon)
Re: Reverse Lights
« Reply #3 on: 08 November 2008, 23:04:09 »
Just a notched bridge to engage gear lever. If all checks have shown nothing probably be the selector switch on offside of gearbox needs to be removed and cleaned with what Albatross said. Switch cleaner spray :y
pablo
  • wexford roi
Re: Reverse Lights
« Reply #4 on: 16 November 2008, 12:25:56 »
have you checked the wiring which runs from boot compartment to boot lid,check for broken wires where the loom bends as bootlid opens and closes,if broken a little solder and wrap with insulation tape.
