Author Topic: Help needed-ashtray drawer  (Read 2158 times)
Lagondanet
  • Bedfordshire
  • The Omega is gone!
    • Lagondanet
« on: 10 November 2008, 12:06:42 »
The (pop-out) ashtray/lighter drawer below the music system will not shut. It feels as if something (a screw or clip) has fallen behind it.
How do you get the drawer out?
Thanks for any advice.
Re: Help needed-ashtray drawer
« Reply #1 on: 10 November 2008, 13:02:16 »
Lift out the inner part of the ashtray (where you dump your ash). There should be three screws. You only need to remove the middle screw and out it comes. :y
Lagondanet
  • Bedfordshire
    • Lagondanet
« Reply #2 on: 10 November 2008, 15:54:58 »
Thanks I'll Try that.
Derek_in_Penzance
  • Penzance, Cornwall
« Reply #3 on: 10 November 2008, 18:09:08 »
I have the same problem!
Go to Facebook and become a Fan of the GM6 Spares Facebook page. Omegas dismantling, mail order parts & servicing. Tech 2 services available.
Lagondanet
  • Bedfordshire
    • Lagondanet
« Reply #4 on: 15 November 2008, 16:52:58 »
RobG & Derek
I took out the small inner tray. Right behind the drawer there are 3 screws. I took out the middle one but it did NOT release the drawer.
What am I doing wrong?
« Reply #5 on: 15 November 2008, 17:02:35 »
Look here. You may have to remove all three.
http://www.omegaowners.com/forum/YaBB.pl?num=1225962149 :y :y
Lagondanet
  • Bedfordshire
    • Lagondanet
« Reply #6 on: 15 November 2008, 17:41:43 »
Thanks. I will have another go!
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #7 on: 15 November 2008, 19:03:13 »
the "middle screw" should be through a half inch hole on the backplate if you like of the cig tray (makes it easier in an auto to shift it into 1st)
V8!!!!
Lagondanet
  • Bedfordshire
    • Lagondanet
« Reply #8 on: 16 November 2008, 17:10:44 »
You were absolutely right. Thanks.
The middle screw & then pull as there is also a connector plug at the back to disengage.
5 minute job.
The culprit was a small bit of plastic which had broken off the back of the lighter which can be rather flimsy if you push/pull plugs into it too roughly. Yes put the stick in 1st to get more room.
