Author Topic: Normal temp on 2.5 TD  (Read 1004 times)
chartz
  • Burgundy
« on: 16 November 2008, 18:17:12 »
I've just had my thermostat changed and now the temp is about 95 °C. Was 85 °C max prior to that. Is it the same for you ?
Thanks.
Re: Normal temp on 2.5 TD
« Reply #1 on: 16 November 2008, 18:36:59 »
mine runs at 95C all the time
chartz
  • Burgundy
« Reply #2 on: 16 November 2008, 18:46:00 »
Thanks. So I guess this is correct. Do you hear your viscous fan from time to time ?
Another query : when outside temperature is cold, does the radiator remain cold or not ?
« Reply #3 on: 16 November 2008, 18:51:27 »
pmsl - only when it falls off the shelf in the garage  ;D
« Last Edit: 16 November 2008, 18:51:48 by TheBoy »
chartz
  • Burgundy
« Reply #4 on: 16 November 2008, 18:53:00 »
As Hugh Grant would put it—ah, right, right.
What about the radiator then ?
« Reply #5 on: 16 November 2008, 20:30:01 »
my rad heats up, as expected
