Author Topic: MAF Sensor  (Read 3635 times)
Kieran
  • Dorset
MAF Sensor
« on: 17 November 2008, 08:44:01 »
Hello all
After spending an afternoon at Kevins getting my car gearbox upgraded which has made a big improvement to the car all thanks to Kevin we did come across a fault with the MAF sensor. Tried to clean it but it looks like i will have to purchase a new one . The question is does anyone now where to get one apart from Vauxhall which i am sure will rip me off.
Cheers
Re: MAF Sensor
« Reply #1 on: 17 November 2008, 08:48:00 »
Try one of the breakers on OOF  :y
Kieran
  • Dorset
Re: MAF Sensor
« Reply #2 on: 17 November 2008, 08:50:33 »
Thanks
Just put an add in the wanted section so will see what comes up :y
Albatross
  • Bedford
  • An LSD & an S2000!
Re: MAF Sensor
« Reply #3 on: 17 November 2008, 09:02:48 »
I just called my Vx stealers this morning and they have offered me one for £130 rather than the full retail of £180.
This rate is because they know me and always give me TC price discount rates on whatever I buy whether it is listed or not.
I have the same issues as you (0170 & 0173) on my 3.2, and I'm just going to buy a new one out of frustration and to KNOW that it is fixed.
I am doing this on the strength of the diagnostics work that Kevin did to your car this weekend.
Read this thread for full details.
http://www.omegaowners.com/forum/YaBB.pl?num=1219699194
Kieran
  • Dorset
Re: MAF Sensor
« Reply #4 on: 17 November 2008, 09:10:51 »
Kevin did mention that you have the same problem and i know how frustrating it can be >:(. I hope that the new sensor fixes your it but for £180 i think i will try a second hand unit first :-/.When we swopped it over for Kevins one it cured the problem so fingers crossed :y
Re: MAF Sensor
« Reply #5 on: 17 November 2008, 09:12:05 »
Just posted the ebay listings against your wanted add
Re: MAF Sensor
« Reply #6 on: 17 November 2008, 09:13:29 »
Interestingly, autovaux seem to think the 3.0 and 2.5 one is the same.....I am not so sure (plug shape!)
Kieran
  • Dorset
Re: MAF Sensor
« Reply #7 on: 17 November 2008, 09:15:44 »
Thanks just had a look  :y. Albatross have a look in the wanted section first and check the ebay link there. Could be cheaper than Vauxhall direct
MutantCav
  • Gainsborough
Re: MAF Sensor
« Reply #8 on: 17 November 2008, 09:30:07 »
Whats the car Kieran, I have one or two here depending on plug shape...
Re: MAF Sensor
« Reply #9 on: 17 November 2008, 10:09:24 »
Albatross, if you want to borrow an ELM cable to double check the live data before you jump, I might be able to help.
Might be worth posting the Bosch part number from the side of the MAF. The 2.6 / 3.2 don't have a separate intake air temperature sensor. Not sure if that makes the MAF sensor different to the 2.5/3.0. :-/
Re: MAF Sensor
« Reply #10 on: 17 November 2008, 10:13:17 »
Its an interesting one as the 2.5/3.0 makes little or no use of the air temp in the correction anyway. Which is not surprising when you consider that air mass has already taken air temp into consideration anyway effectively!
Re: MAF Sensor
« Reply #11 on: 17 November 2008, 10:15:56 »
would the maf know the air temp? surely it can only know the amount of air, not its temp/ Obviously this would vary with temp for a given load though...
Albatross
  • Bedford
Re: MAF Sensor
« Reply #12 on: 17 November 2008, 10:41:01 »
Could I get this checked with one of those cheapo Tech2's? My local garage mate has a red thing that he can see most DTC codes etc., but I understand that they are limited?
If so, what would we need to do?
Albatross
  • Bedford
Re: MAF Sensor
« Reply #13 on: 17 November 2008, 10:44:35 »
Thanks for that. Online on eBay they are £115.00 BuyItNow, so for the sake of £15 I'll live with using my local Vx stealers. They are very good to me and I have saved a hell of a lot more than that by going through them until now, so i don't mind "investing" a little in that relationship.
Re: MAF Sensor
« Reply #14 on: 17 November 2008, 10:44:43 »
It does not need to know the air temp in reality....just the mass of the air......and then it supplies a corresponding mass of fuel  :y
