Author Topic: Eratic Idle  (Read 1655 times)
nen3906
  • Tamworth
Eratic Idle
« on: 19 November 2008, 16:43:51 »
Guys
      My 2.5V6 R plate has only just started doing its little thing.  When stationary at lights in N, the revs will die, but at the last minute before it stalls the revs suddenly blast to 900rpm, then back to die, then back to 900.
  It doesnt happen often, twice a month if that, and I have completed the Paperclip test with nothing showing up.
Any ideas ??
kevpuk
  • Poole
Re: Eratic Idle
« Reply #1 on: 19 November 2008, 16:46:34 »
Idle control valve - just had the same problem and the peeps here told me what to do :)
kevpuk
  • Poole
Re: Eratic Idle
« Reply #2 on: 19 November 2008, 16:49:38 »
See here
« Last Edit: 19 November 2008, 16:50:32 by kevpuk »
nen3906
  • Tamworth
Re: Eratic Idle
« Reply #3 on: 19 November 2008, 16:56:08 »
Cool, thank you........
Is it easy to replace ?
kevpuk
  • Poole
Re: Eratic Idle
« Reply #4 on: 19 November 2008, 17:14:17 »
Quite likely just needs a good clean......took me about 30 mins, tops, and is good as new :D
nen3906
  • Tamworth
Re: Eratic Idle
« Reply #5 on: 19 November 2008, 17:17:08 »
Where is it on the engine  lol :y
MutantCav
  • Gainsborough
Re: Eratic Idle
« Reply #6 on: 19 November 2008, 17:18:16 »
Very easy to take off...soak the metal bit in carb cleaner and give it a good clean out...make sure you lube the black rubber holder to make it a firm fit back into the plenum after...
kevpuk
  • Poole
Re: Eratic Idle
« Reply #7 on: 19 November 2008, 17:41:50 »
Pretty sure there are pics in the post I linked to......that was my source :)
MutantCav
  • Gainsborough
Re: Eratic Idle
« Reply #8 on: 19 November 2008, 17:45:42 »
Replacing is the opposite of removing lol VERY easy :)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: Eratic Idle
« Reply #9 on: 19 November 2008, 19:05:08 »
if you look under the bonnet at the plenium (thing inbetween the two banks of cylinders)
on the r.hand side of it towards the front there's a cylindrical shaped thing on it's side with a black rubber holder, this is the idle control valve (to take it off you slide it out of the rubber sleeve/holder after releasing the connector on the rear of it (squeeze the two loops inwards towards the plug and tug off) then remove the inch roughly pipe to the bagpipes which will release it apart from a thin pipe... just tilt it over and spray carb cleaner into it until it seems "cleaned out" haha
V8!!!!
Re: Eratic Idle
« Reply #10 on: 19 November 2008, 19:12:36 »
the one with the ICV label
