Author Topic: fault codes 73...  (Read 2273 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
fault codes 73...
« on: 19 November 2008, 20:34:12 »
hiya, i know fault code 73 is maf sensor voltage low but does this mean its buggered or does it mean iv probably got an airleak?
iv just sorted an airleak from the icv!
also i had 21 but i'v changed tps so should be ok
thanks
V8!!!!
SheWhoMustNotBeOUTBID
  • Drives the only front wheel drive miggy
Re: fault codes 73...
« Reply #1 on: 19 November 2008, 20:40:59 »
I've asked Jue about this and he just said 'TB' lol.., try The Boy I think lolol, sorry we can't help.
« Last Edit: 19 November 2008, 20:41:30 by swmbowithattitude »
Save The Earth.., its the only planet with chocolate!!!!!!!!!!!!!!!
I wish admins were clever enough to remember to let me on the forum cause I do good coffee in return!
« Reply #2 on: 19 November 2008, 21:20:04 »
thanks
Sudgests an air leak......is the ECU light still on?
ngrainqey
  • rotherham
« Reply #3 on: 19 November 2008, 21:27:12 »
i need to clear the engine check light just to make sure but i think its cleared now
V8!!!!
« Reply #4 on: 19 November 2008, 21:28:06 »
If the fault is gone then the light will go off.....the code will remain stored though
ngrainqey
  • rotherham
« Reply #5 on: 19 November 2008, 21:29:01 »
ok thanks matey, is it true te ecu will lose the saved codes i you disconnect the battery for a couple of minutes or so?
thanks
V8!!!!
« Reply #6 on: 19 November 2008, 21:34:03 »
thanks
Nope....its a myth.
Most codes will clear after a number of clean starts (20+)
ngrainqey
  • rotherham
« Reply #7 on: 19 November 2008, 21:53:42 »
oh dear...
what about the turn the ignition on and off quickly 25+ times? another myth?
might just buy a cheapo tech2 haha!
V8!!!!
« Reply #8 on: 19 November 2008, 22:01:12 »
oh dear...
Yep ;D
