Author Topic: Gearbox Code P0730  (Read 1436 times)
johnnycboy
  • Colchester
Gearbox Code P0730
« on: 20 November 2008, 21:27:02 »
Had this code before when accumulator cap and circlip fell out. since been replaced.  After about 20 miles tonight - autobox warning came up and felt as though the back end was trying to pull it self apart.  Managed to drive in 3rd gear as the 4th gear will not lock up.  Not good for fuel consumption had to drive sixty miles home in 3rd.  Can't see anything untoward.  any ideas please. :'(
Re: Gearbox Code P0730
« Reply #1 on: 20 November 2008, 21:35:12 »
assuming 820 ecu, its gear ratio incorrect, which invariably is a mechanical fault
johnnycboy
  • Colchester
« Reply #2 on: 20 November 2008, 21:59:02 »
TB
was a mechanical fault last time when accumalator cap and spring fell out along with all the atf.  since been replaced and done at least 400 mile,  can't work out what has happened.  Is it possible for the selector switch to cause this if it gets wet, or is it another box jobby.
« Reply #3 on: 20 November 2008, 22:10:32 »
TB
switch normally throws a range fault.
johnnycboy
  • Colchester
« Reply #4 on: 20 November 2008, 22:15:16 »
TB
another box then presumbly :-/
« Reply #5 on: 20 November 2008, 22:15:50 »
Markey Mark has 2 x ar35 for sale cheap at the moment,if you need one. :y
johnnycboy
  • Colchester
« Reply #6 on: 20 November 2008, 22:22:18 »
cheers albitz :y
already had a word with him just in case.  certainly looking like another box. >:(
« Reply #7 on: 20 November 2008, 22:24:57 »
Might be easier than pulling the old one apart. :y
might be able to help if you need a pair of hands.
johnnycboy
  • Colchester
« Reply #8 on: 20 November 2008, 22:31:17 »
cheers
may take you up on that.  let you know. :y
« Reply #9 on: 20 November 2008, 22:33:28 »
should have a few days off next week,gimme a shout when your going to start spannering. :y
p.s. you wont need to supply free shampoo (after atf shower) got no hair to wash. :y ;D
« Last Edit: 20 November 2008, 22:34:40 by albitz »
johnnycboy
  • Colchester
« Reply #10 on: 20 November 2008, 22:42:31 »
you and me both then.  not sure when i'l be doing it yet though.  i'l give you a shout to see if you are around. :y
