Author Topic: using vectra inlet manifolds/plenium thing...  (Read 1757 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« on: 21 November 2008, 21:37:36 »
has anybody tried it/know what it runs like?
without the multiram apparently the engine runs like a sack of turd.
if you can use it then can you get away with the vectra icv or have to bodge and omega one on?
thanks
V8!!!!
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: using vectra inlet manifolds/plenium thing...
« Reply #1 on: 21 November 2008, 21:42:05 »
vectras sensors use different connectors to the mig ! i have a veccy plenum set with courtenay throttle body i dont think it will work marksDTM problably knows!
Ian_D
  • York
« Reply #2 on: 21 November 2008, 21:48:57 »
Ive wondered this, as the vectra inlets sound far better than the omega IMO
Vectras just sound so angry!  ;D
[size=12]
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #3 on: 21 November 2008, 21:52:29 »
so does the omega if you stick a induction kit on it! the omega sounds like the vectra just its refined and has lots of sound proofing unlike the vectra!
vectras go wrong lots omegas dont!
    • 530D M Sport, 330i Coupe
« Reply #4 on: 21 November 2008, 21:56:51 »
The plenum setup on the Vectra was apparently the best flowing design of all the varients according to the people who designed it, however, the multiram and bagpipe arrangement on the Omega is far better than the Vectra's restricted setup.
« Last Edit: 21 November 2008, 21:57:32 by VXL_V6 »
Ian_D
  • York
« Reply #5 on: 21 November 2008, 21:59:39 »
Hmm..Multirams not working correctly on the omega. But reving both my 2.5 vec and the 3.0 omega, the 2.5 sounds better BY FAR. Thats with a cone filter on them.
[size=12]
ngrainqey
  • rotherham
« Reply #6 on: 21 November 2008, 22:08:37 »
what about if i swap bits over so i have the omega connectors?
i could just have a 2 to 1 pipe from the bagpipes to the veccy intake :P
just need more engine bay room!
might be getting a t25 garret this month! need roooom! lol
V8!!!!
« Reply #7 on: 22 November 2008, 08:57:51 »
I suspect the veccy intake may be less responsive....as it has a single large throttle butterfly and not twin medium sized ones.
I also dont buy the 'less restrictive' commen.....just looking at it I would say thats not the case!
Its also more of a compromise to get it all to fit which I suspect is why it sounds more angry as it wont be nearly as well tuned!
« Last Edit: 22 November 2008, 08:58:14 by Mark »
