Author Topic: 2.5V6 Holding power when 'lifting off' the gas  (Read 2911 times)
Budgie
  • Lincolnshire
« on: 22 November 2008, 17:07:43 »
Hi,
I had a good look around the forum before posting this and couldn't find any other reference to this condition. Anyhoo apologies if I missed a similar post.
My car is exhibiting a condition which may or may not be a fault symptom and I would be interested to learn if any other owner has had a similar experience.
My car is an Elite 2.5 V6 Auto 2000 X Reg
The condition is related to the rate at which the car slows down after lifting off the gas pedal.
The condition is most noticeable during urban driving and manifests itself as follows: -
When lifting off at around 50mph the car will slow quite rapidly (as expected) to 42-43mph. At this point it will hold power and speed as if the cruise control had been selected. It will however after 10 seconds or so continue to slow (albeit at a reduced rate) to around 32mph when it repeats the above cycle again. The same applies when lifting off at 40mph - i.e. slows to 32mph and then holds power and speed.
Now this can be fairly disturbing when driving around town to say nothing of the brake wear increase.  :o
My local VX man says this is normal for the electronic autobox fitted to the 2.5V6 Facelift.
My engine idle speed when stationary in 'P' or 'N' appears to be [size=12]around 600**[/size] rpm however this does of course increase as expected when selecting a forward or reverse gear during parking. Curiously when selecting 'D' whilst stationary the car does seem to 'amble' forward rather than the expected 'creep'.
Other info - have recently had cam covers and gaskets/'O' rings replaced as well as breathers cleaned.
I would welcome any sound advice or comments anyone may be able to offer.  :y
** Update - Ooops! have now cleaned bi-focals   :-[ it is nearer 550 - 600
« Last Edit: 22 November 2008, 18:08:27 by Budgie »
I spend far too much money on my Omega
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: 2.5V6 Holding power when 'lifting off' the gas
« Reply #1 on: 22 November 2008, 17:15:40 »
would have said it was the idle speed set too high or the throttle sticking...
the auto doesnt have as much engine braking...
why dont you manually drop down next time your out and see what happens?
post results?
V8!!!!
Richard A
  • Aldridge, West Midlands
« Reply #2 on: 22 November 2008, 17:52:18 »
Idle speed when in gear should be about 550rpm, out of gear normal tick over should be between 550 to 600rpm, just under 1000rpm is wrong, ie not correct, check for air leaks (vacuum pipes), clean the idle valve, check the throttle body is clean and returns to the stop when not under pressure.
regards
richard a
richard a
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #3 on: 22 November 2008, 17:56:29 »
your idle does seem a little high, it should be about 650 or 700 with climate on.
my 2.6 doesn't seem to slow very well off the gearbox, i have just put if down to it being a feature of autoboxes
Budgie
  • Lincolnshire
« Reply #4 on: 22 November 2008, 18:09:52 »
Have amended post - sorry guys yes it actually is around 600 rpm
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #5 on: 22 November 2008, 18:24:30 »
if that's the case then yes that does sound right
Budgie
  • Lincolnshire
« Reply #6 on: 17 January 2013, 17:43:51 »
After living with this condition sine 2008 I have at last associated it with the AC climate control being activated. If I switch the AC off the engine's deceleration is normal.
« Reply #7 on: 17 January 2013, 19:37:09 »
The idle speed should increase a little to compensate for the air con, but not to a noticeable degree. I wonder if the ICV is sticking somewhere around the 600 RPM point?
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #8 on: 17 January 2013, 20:04:56 »
My thoughts are sticky ICV or dirty throtle body :y
Budgie
  • Lincolnshire
« Reply #9 on: 19 January 2013, 11:40:34 »
Thanks for the advice guys - it's appreciated.  :y
symes
  • oxford
    • R reg 940 volvo
« Reply #10 on: 19 January 2013, 14:55:12 »
Clean throttle butterfly linkages-were throttle cable goes=reckon its dry/sticking=spray it with wd40 or any lube mate :y :y :y
Page created in 0.025 seconds with 16 queries.
