Author Topic: Windscreen Misting Up  (Read 7727 times)
nixoro
  • Hitchin, Herts
Re: Windscreen Misting Up
« Reply #15 on: 21 November 2008, 17:14:18 »
sonds like you got a pin hole in the heater matrix,you could always check for loose connections  at point of entry to matrix,could suggest you try a rad sealer?if all else fails as matrix not so handy to gain access and remove
Surely if there was a Matrix problem the car would overheat etc :-/
nixoro
  • Hitchin, Herts
« Reply #16 on: 21 November 2008, 17:15:11 »
I find that if I don't keep the window clean it mists up easily. As my window gets more dirt on it I can use the eco button less and less!
Have to admit the car could do with a good clean inside and out :(
nixoro
  • Hitchin, Herts
« Reply #17 on: 21 November 2008, 17:16:35 »
Think I sorted mine, changed pollen filter, checked vents in boot, all fine, then washed car and found about a gallon of water in the scuttle, the rubber tube was blocked solid, cleaned it out and woopee seems to be ok now ;D
I think I may just get a new pollen filter for good measure any Idea on what the prices are from VX without trade club
chrismec
  • Poole Dorset
« Reply #18 on: 22 November 2008, 14:00:12 »
Got mine from local factors, £5.39 :)
If it ain't broke don't fix it
Martin_1962
« Reply #19 on: 22 November 2008, 16:45:40 »
Keeping air con on tends to help too
gwa
  • Peterborough
  • Ginger With Attitude
« Reply #20 on: 22 November 2008, 18:19:10 »
Nice one, glad to hear you are sorted  :y :y :y :y
If it ain't fun, it ain't worth doin
nixoro
  • Hitchin, Herts
« Reply #21 on: 22 November 2008, 19:51:26 »
So far I still need to replace the filter but for the moment as mentioned the AC does help alot.
Shall be visiting my local motor factors asap to see what they cost :y
jonathanh
  • coventry
« Reply #22 on: 22 November 2008, 20:40:29 »
I have the same problems:  basically there is a lot of dampness that condensates of the screen.  one solution is to dry the air with the aircon; the other is to stop the moisture on the screen by giving at a good clean with glass cleaner/polish such asd autoglass glass cleaner.polish
