Author Topic: Windscreen Misting Up  (Read 7788 times)
nixoro
  • Hitchin, Herts
« on: 13 November 2008, 10:23:09 »
Whats the recommended to sort this problem is it to replace the pollen filter or the air filter cant remember.
Cheers
Roy
Re: Windscreen Misting Up
« Reply #1 on: 13 November 2008, 10:25:41 »
Check the pollen filter, scuttle drain and the vents in the boot (in the bottom of the side cubby hole on a saloon and and the rear of the spare wheel well on an estate)
nixoro
  • Hitchin, Herts
« Reply #2 on: 13 November 2008, 10:28:03 »
Cheers Mark I shall take a look during lunch  :y
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #3 on: 13 November 2008, 11:54:21 »
I find less heavy breathing helps! ;D
nixoro
  • Hitchin, Herts
« Reply #4 on: 13 November 2008, 18:11:24 »
Funny lol  ;D ;D ;D ;D
I checked the scuttle the rear air vents were clear which they were.
What do I look for on the pollen filter as it still looks new  :-/
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #5 on: 13 November 2008, 18:25:30 »
if you have alot of junk in that boot cubby space then that stops it working too!
best thing to do is to keep the fan on number 1 on the windscreen- thats what i do and it keeps the air circulating... mine steams up easy as anything without the fan on but i breath very heavily im told haha!
V8!!!!
« Reply #6 on: 13 November 2008, 18:43:45 »
Check if the pollen filter has got damp,if so put it somewhere warm overnight or buy a new one.
« Reply #7 on: 13 November 2008, 18:50:17 »
is the ac working and eco off?
No damp in the car, carpets dry, including the rear foot well?
nixoro
  • Hitchin, Herts
« Reply #8 on: 14 November 2008, 19:34:07 »
Funny you say that I did have a fair bit in there but now the vents are clear. Unfortunately its only slightly better still mists up.
nixoro
  • Hitchin, Herts
« Reply #9 on: 14 November 2008, 19:35:10 »
Might have to look at this idea you never know.
If I was to get a new filter which one would I need? 2 types from what Ive heard.
nixoro
  • Hitchin, Herts
« Reply #10 on: 14 November 2008, 19:37:11 »
Unforunately I dont have an eco button but a circulate button and twist dials  :'(
I have checked the carpets, and the rear footwells are dry.
gwa
  • Peterborough
  • Ginger With Attitude
« Reply #11 on: 15 November 2008, 07:00:55 »
Maybe a good idea but constant blowing on the screen will put a film over it which will attract moisture and thus 'mist up'  :-/ :-/ :-/ :-/ :-/
If it ain't fun, it ain't worth doin
pablo
  • wexford roi
« Reply #12 on: 16 November 2008, 12:09:04 »
sonds like you got a pin hole in the heater matrix,you could always check for loose connections  at point of entry to matrix,could suggest you try a rad sealer?if all else fails as matrix not so handy to gain access and remove
chrismec
  • Poole Dorset
« Reply #13 on: 21 November 2008, 11:41:49 »
Think I sorted mine, changed pollen filter, checked vents in boot, all fine, then washed car and found about a gallon of water in the scuttle, the rubber tube was blocked solid, cleaned it out and woopee seems to be ok now ;D
If it ain't broke don't fix it
Rob James
  • Sheffield
« Reply #14 on: 21 November 2008, 17:05:24 »
I find that if I don't keep the window clean it mists up easily. As my window gets more dirt on it I can use the eco button less and less!
