Author Topic: Exhaust Manifold Woes  (Read 4141 times)
nixoro
  • Hitchin, Herts
« on: 21 November 2008, 08:20:41 »
I was traveling up a hill with speed humps the other week and had to dodge some idiot coming the opposite way who was speeding forcing me to bounce awkwardly on a speed hump, before asked I was doing around 15mph if that and had to go to the centre of the road as cars were parked to the left of me.
My car now drives like a crap and I discovered yesterday the manifold is ticking when cold >:(
What are the chances of more damage having occurred.
I am going to be removing the manifold tomorrow to get a better look.
More work  :(
Re: Exhaust Manifold Woes
« Reply #1 on: 21 November 2008, 08:23:19 »
First question has to be.....did the car actualy ground out?
nixoro
  • Hitchin, Herts
« Reply #2 on: 21 November 2008, 08:25:29 »
I think it did cos there was an almighty thud >:( at the time I stopped and had a brief look under the car but had to continue as was late for work.
The car though once warmed up drives nice.
nixoro
  • Hitchin, Herts
« Reply #3 on: 21 November 2008, 17:19:00 »
Any other Ideas on this would be greatly appreciated as its been a while since doing any major work on my car, just thinking their maybe more damage than 1st thought you never know.
markey mark
  • SLady bitshorpe north lincs
« Reply #4 on: 21 November 2008, 17:27:08 »
could you have crushed a cat bud ??  :-/
nixoro
  • Hitchin, Herts
« Reply #5 on: 21 November 2008, 17:31:42 »
That was a thought of mine but shall be giving good look over tomorrow so should be the moment of truth, shall be posting up with my findings.
nixoro
  • Hitchin, Herts
« Reply #6 on: 22 November 2008, 19:48:26 »
Well I had a look at the exhaust today and the manifold, the exhaust still looks solid and I checked all the joins and they look to be leak free. Damn it was cold  :(
The Manifold however I found a loose bolt in the top row and missing  2 bolts in the lower row which annoyed me fortunately no snapped studs.
I had to fit a new bolt in the one which was loose, used my tap & die tool to clean and check the thread in the head, bolt tightened in spot on.
There were 2 lower bolts which i managed to put new bolts in as they were loose but I dont hold much hope for them at the moment as I had a garage do some work on the car a while back when they did the HG and I think they may have mucked the threads up good and proper.
Still moment of truth will be in the morning with a cold start.
My plans for the future are to totally remove the manifold and retap all the threads and fit a new set of bolts.
« Last Edit: 22 November 2008, 19:49:23 by nixoro »
SheWhoMustNotBeOUTBID
  • Drives the only front wheel drive miggy
« Reply #7 on: 22 November 2008, 20:19:37 »
My other half has been known to do this a couple of times.  Its a bit of a pain but perfectly doable.  Good luck
Save The Earth.., its the only planet with chocolate!!!!!!!!!!!!!!!
I wish admins were clever enough to remember to let me on the forum cause I do good coffee in return!
nixoro
  • Hitchin, Herts
« Reply #8 on: 22 November 2008, 20:25:22 »
Cheers  :y its annoying as I have done the manifold a few times now what with failing gaskets and bolts, I had it spot on before taking to a garage and knocking the underside of the car.
Last time I removed the manaifold it was refitted and was spot on all torqued correctly, now regretting letting a garage get there mits on my omega and going near the speed humps always the way a short can cause problems ::).
Just need to find a good dry, warm day and crack on with it.
« Last Edit: 22 November 2008, 20:27:00 by nixoro »
bighed
  • Shropshire
« Reply #9 on: 22 November 2008, 21:34:09 »
Not sure if there is a how to on replacing manifold gasket on here for the V6  :-/ (correct me if Im wrong) but would you mind doing one as i got to do my drivers side at some point.  :y Sounds crap when cold dont it  ;D ;D ;D
Page created in 0.027 seconds with 16 queries.
