Author Topic: head of and can see water !  (Read 1581 times)
mick-1975
  • nottingham
« on: 22 November 2008, 21:19:41 »
  hi without me going out there looking as getting cold now
  i have a car in which i have taken the head of to clean and skim as the gasket went ,   i have taken the hose off to drain the water but as u look at the block the holes round the piston bores have got water in .
  is there a way of getting this out ???  :y
  the oil is still in the sump at the mo to !
  thanks
« Last Edit: 22 November 2008, 21:25:06 by mick-1975 »
Jukeboxnut
  • West Sussex
    • 2004 2.2 auto CDX estate
Re: head of and can see water !
« Reply #1 on: 22 November 2008, 21:51:33 »
If you remove the water pump most of the water should drain out of the block, what is left will need to to be sucked out with a syringe and tubing if you want to completely empty the block.
markey mark
  • SLady bitshorpe north lincs
« Reply #2 on: 22 November 2008, 22:18:25 »
kitchen roll to get it out the bores ! as said take water pump out will get most of it out ! :y
« Reply #3 on: 22 November 2008, 22:24:53 »
but as your water pump is cam belt driven I'd just suck/syphon it out - less hassle. Unless you're about to change your cam belt!  :y
« Reply #4 on: 22 November 2008, 22:25:43 »
If the head is off, I'd suggest the belt probably is too? ::)
« Reply #5 on: 22 November 2008, 22:26:27 »
Doh!  ;D  ;D  ;D
That's cos my mind is on my pox ridden central heating.  ::)  :y
« Last Edit: 22 November 2008, 22:28:27 by Andy_B »
« Reply #6 on: 22 November 2008, 22:27:03 »
Doh!
 :D
« Reply #7 on: 22 November 2008, 23:08:07 »
Doh!
 :D
:D ;D :D ;D :D
« Reply #8 on: 22 November 2008, 23:28:38 »
Doh!
 :D
:D ;D :D ;D :D
I can't help being stupid!  ;D
markey mark
« Reply #9 on: 23 November 2008, 05:19:31 »
Doh!
 :D
:D ;D :D ;D :D
we know andy !! ;D ;D
« Reply #10 on: 23 November 2008, 09:52:44 »
Doh!
 :D
:D ;D :D ;D :D
You don't have to agree with me ......  :y
