Author Topic: v6 oil cooler  (Read 2821 times)
Bandit127
Re: v6 oil cooler
« Reply #15 on: 23 November 2008, 18:31:49 »
I know it has already been said above, but to clarify and re-iterate.
The oil cooler was a known fault until they replaced them with Stainless steel jobbies. By not fitting a genuine one you'll only be asking for trouble and re-introduce the "fault".
It is often not worth going to Vx for parts, but sometimes it is strongly recommended. It depends on which part, and the oil cooler is one of them
Do you know when they changed? Is it possible that this is something I don't need to worry about failing on my 2000 reg pre facellift?
TIA
Re: v6 oil cooler
« Reply #16 on: 23 November 2008, 18:33:38 »
TIA
I've seen 2000 models fail  :'(
Bandit127
Re: v6 oil cooler
« Reply #17 on: 23 November 2008, 19:00:51 »
TIA
OK, will carry on worrying then  ;D
My antifreeze mix is 50%, I am careful with that knowing how important it is in maintaining the oil cooler.
Glynn
  • wirral
  • 3 LTR ELITE
Re: v6 oil cooler
« Reply #18 on: 23 November 2008, 21:34:41 »
As said of Vauxhall, but make sure you get the KIT at £90ish, not the individual parts at £300ish!
Edit, seen you are local, Lookers at Deeside know the kit you need  :y
handy to know  :y...i worked in the motor trade till a few months ago , so hopefully i can use some contacts to get trade
[img name=signat_img_resize]http://i24.photobucket.com/albums/c18/glynn969/P8130334-1.jpg[/IMG]
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: v6 oil cooler
« Reply #19 on: 23 November 2008, 22:36:17 »
why not add an external oil cooler?
*cough cough* can anybody suggest any suitable oil coolers for using as an external one...
somebody off the saab forum suggested the c20let/xe one
thanks
V8!!!!
Re: v6 oil cooler
« Reply #20 on: 24 November 2008, 08:58:26 »
TIA
Around 1995.....and any will fail if the coolant is miss treated....
« Last Edit: 24 November 2008, 08:58:45 by Mark »
