Author Topic: will my 3.2 airflow meter work on a 2.5v6  (Read 960 times)
Simon_Omega
« on: 24 November 2008, 19:14:02 »
im trying to trouble shoot problem with a 2.5 v6 on a 2000 W with airflow part number 280 217 519
and i also own a 3.2 mv6 with part number 0281 00218 and wondered:
 if i try out the 3.2 one in the 2.5 engine bay to see if the engine works any better, will it be ok or do i need an exact match?
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: will my 3.2 airflow meter work on a 2.5v6
« Reply #1 on: 24 November 2008, 19:15:56 »
no...... different connectors! i think the 3.2 will have an oval connector and the 2.5 will have a square connector!
    • 530D M Sport, 330i Coupe
« Reply #2 on: 24 November 2008, 19:16:44 »
Different part, 3.2 MAF also does Air temp whereas 2.5 and 3.0 have seperate Air temp sensor.
Simon_Omega
« Reply #3 on: 24 November 2008, 19:19:15 »
ok cheers case closed then!
what it is,  its running rough and not combusting properly, but all spark leads working ok,   there is a fault code in the memory (but not lit currently) about the maf, but i did unplug the maf during fault finding. so that could be why its logged.   its a bloody nuisance as i have 5 offers on it on flea bay yet cant iron out the running problem! rest of car is like new and like a dream!
